most important spot to put first slab of absorptive material
I currently have an ugly corner desk that turns my equilateral stereo imaging triangle into a diamond!! I heard you should not have your setup in a corner so I am going to be rearranging and moving my setup to a better location...so let's say I'm facing a wall now instead of a corner...where would it typically be most important to put my first slab of absorption/diffusion?? I would think it would be directly behind the monitors against the wooden walls...is this a good place to start? Also, some acoustic foam has the familiar "teeth" cut into it..others look completely flat (and still other look like carpeting wrapped around a peice of wood)...whats better/best?
Thanks =) |
Long story - Basically, you *might* want a small amount of foam on the side walls between you and the monitors.
You most definitely will want broadband / bass trapping in the rear corners (that's the 4" thick rockwool/mineral wool/OC703 stuff you normally see wrapped in cloth). Probably start here - www.realtraps.com and go to the acoustics articles. That will make a lot more sense than I do before my first cup of coffee. |
| DIY quadratic diffuser | RICK FITZPATRICK | Studio Building & Display | 71 | 01-15-2003 08:53 |
