Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-30-2005
ericlingus ericlingus is offline
Force of Nature
ericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond repute
Connecting Triton to line in of audio interface
I want to connect my Triton LE to my computer line in. There are two audio outputs on my triton(monoL and R) To get a stereo sound could I use a Y cable?(1/4" mono male to 2 - 1/4" mono male connections.)
Old 12-30-2005
Sampler's Avatar
Sampler Sampler is offline
Junior Member
Sampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond reputeSampler has a reputation beyond repute
A Y-cable will convert a stereo source into a mono source (2 inputs-->1 input). You can also connect the Left output of the Triton to the input on your computer. You will not get a stereo sound, but you can double and pan your tracks in your sequencer to spread the sound across the stereo spectrum.
Are you using the built in soundcard on your computer? If you are, the inputs are probably 1/8", in which case you'll need an adapter for the 1/4" cables. If you're using an external soundcard/interface (with at least two inputs), you can connect the Left and Right outputs of the Triton to the 2 inputs on the soundcard, and achieve a stereo sound that way.
Unless you're going to be working with sounds that pan a lot, stereo v. mono is not a big deal.
Old 12-30-2005
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Good call sampler.
I've got an LE as well I ran each of the outs to seperate inputs on my Delta1010. To support what Sampler said, you need to be able to take each of the outputs to seperate tracks so that they can be panned in the final mix.
Nice keyboard btw although mine gets more time as a midi controller these days...sorry,...I digress.
She's not the boss of me
Old 12-30-2005
altiris's Avatar
altiris altiris is offline
Force of Nature
altiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond repute
http://www.audiogear.com/cgi-bin/sho...&preadd=action
this adaptor will to the trick. here are some other adaptors that can help with other connections. http://www.audiogear.com/Audio-Adapters-Miniplug.html
It's half full when you fill it and half empty when you spill it.http://dl2.glitter-graphics.net/pub/...jtstrnnu1n.gif
Old 12-30-2005
Force of Nature
thanks for the help. Yeah that 's what I figured I would do. Have a mono track and copy it and pan both tracks hard left and hard right. I have a Presonus Firebox so I don't need that adapter(although I do have a couple anyways). Another question especially for the other LE user. How do you program drums with it? Do you do it via MIDI in a midi sequencer like Cubase and do each part separately(kick,snare,hi hat,etc)? Then to convert it to audio you just plug the triton to the line in on your audio interface and make sure it's on the drum setting you want and just hit record?
Choice of Audio Interface Fortunate Son Digital Recording & Computers 2 05-06-2005 02:08
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
sound card upgrade (usb) sathyan Digital Recording & Computers 3 01-18-2004 13:49
audio interface help allenmertes Digital Recording & Computers 11 01-06-2004 16:56
What the point of an audio interface? karambos2 Digital Recording & Computers 1 04-18-2003 05:45
