Cubase SL3.0 + BFD Drum sampler
Does anyone have any experience with this combination? If so, any help would be appreciated! I'm loading BFD (probably still) as you're reading this, and would like to know if there are any hints on how to get them integrated smoothly... ReWire? VSTi? Which way would be the easiest to get the drum rolls to flow accross the speakers, to get the most natural, open sound? Or is there even a difference?
I use Cubase SX and BFD. I use BFD as a vst plugin. When you save a project that includes BFD as a vst, the BFD setup is saved along with the Cubase project. Here's how I set it up:
Devices, VST Instruments, click on an empty slot, choose BFD Stereo, Group, or All, your choice. For messing around and songwriting, I use BFD Stereo, which is just a stereo output from BFD to Cubase. For more control, I use BFD All, which outputs all BFD channels to Cubase allowing you to apply audio effects to each individual drum mic. All direct drum mics in BFD have pan controls so getting your tom rolls to go across the stereo field should be simple enough to figure out. Add a MIDI track. For the output of the MIDI track, choose BFD. If you have a MIDI controller hooked up, choose it as the MIDI input, if that's what you want. Or, you can use the Groove Library patterns from BFD. Make sure that MIDI out is enabled in BFD if you use the Groove Library patterns. Load a kit up in BFD. If you're using the Groove Librarian, load up some patterns. If you get clicks/pops, cutting out, etc., try switching to 16 bit mode and/or changing the cache sizes in BFD's options. Also, unload any kit pieces that you are'nt using. Check out BFD's options in the manual. As far as getting a natural sound, I try to approach it like a real kit. I pull all faders down in BFD except the overheads. I try to get a good sound by adjusting each drum channels individual trim fader. Then, I start bringing up the direct mic faders as needed. Now I'll play around with eq/compression in Cubase to tame peaks and carve the sounds a bit. After I have a sound I like I'll record a drum track. If I need more ambience, I'll start bringing up room and/or pzm faders. Hope this helps a little. Check out the manual to learn how about BFD's options. Last edited by travelin travis; 12-30-2005 at 18:46.. |
| Drum Recordings Led Zeppelin SOUND!!! | jsanfilippo5 | Drums and Percussion | 4 | 02-16-2005 18:48 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
| How do I get my midi drum track into my mixdown track in cubase? | c_r_a_z_y | Newbies | 1 | 04-01-2002 21:08 |
| Giga sampler with cubase | Richvee | Cubase User Forum | 0 | 10-12-2000 13:42 |
| Recording drum tracks from a sampler... | Dr.D | Recording Techniques | 1 | 07-27-1999 11:19 |
