Hi,
I'm using HS2002 and though the help file clearly tell you can route audio tracks to auxiliairy tracks I can't do it. Choices are limited to bus A-B-C. I'd like to group audio tracks in 3 groups, each group having one reverb and output them to a virtual bus using a final reverb. SergeD |
I haven't used HS2002, but the Sonar version it is based on used to be able to define the number of AUX busses available in the OPTIONS-AUDIO menu.
Ciao, Q.
<insert something witty here> |
Qwerty,
I have AUX busses available but cannot route my audio tracks to them. SergeD |
I'm not familiar with HS2002, but in Sonar you enable the Aux Bus (send) by going to the FX tab in Track View and clicking on the little square in the Bus control area until it "lights up." If the controls for the Bus do not show up already, right click on the track and choose "insert send" from the popup menu and then choose the appropriate bus from the list. |
Thanks dachay2tnr, you're right.
Finally I understood how to send from audio track to auxiliary bus with the faders. SergeD |
So, for example, you can send three tracks of background vocals to a Bus called Vocals, and then route the Vocal Bus to the Main Bus. What this does is, 1) you can still control the volume of each vocal/pan from the individual track faders, 2) you can contol the volume of the Vocals as a single entity using the fader on the Vocal Bus, 3) you can patch one effect onto the Vocal Bus that will handle all three vocals, etc. It was, for me, a dream come true. ![]() |
| mono mixing fundamentals | walters | Recording Techniques | 21 | 05-18-2005 07:52 |
| Mixing Problems | Idgeit | The Rack | 12 | 04-13-2005 17:52 |
| mixing board problems | altiris | Newbies | 9 | 02-24-2005 07:31 |
| Problems mixing down to MP3 in PA 9 | busted kitty | Cakewalk / Sonar Forum | 6 | 03-09-2002 00:34 |
| Problems mixing down to MP3 in PA 9 | busted kitty | Cakewalk / Sonar Forum | 2 | 03-06-2002 15:43 |
