Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 12-19-2005
UNIQNESS UNIQNESS is offline
Newbie
UNIQNESS is on a distinguished road
i have some questions
1. i recorded something from my turntable and i want to chop off very end where it made a static sound. however, cubase will only let me chop off each measure. how do i chop off the tiny part of the recorded track?
2. when i record through the microphone, do i record as a mono track so i can record both L and R with one XLR cable?
3. i rewired with reason and found out that i need redrum in reason to stop playing in this one part. however, reason will not delete the part where i want redrum to stop playing.. how do i do this? (i can delete parts in other tracks without any problem.)
4. when i finish songs and export as an mp3 file, the volume tends to be a lot lower than normal mp3 songs i have. how do i raise the volume so the volume would be about as same as my other mp3's?
5. can you master with cubase SX3? if not, what mastering software do you recommend for music created by cubase SX3?
thanks in advance!
[edit] found the answer for #4 here: http://www.homerecording.com/bbs/sho...d.php?t=181257
Old 12-19-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
3. i rewired with reason and found out that i need redrum in reason to stop playing in this one part. however, reason will not delete the part where i want redrum to stop playing.. i can delete parts in other tracks without any problem.
thanks in advance!
1. you need to turn off "snap to" which is the icon that looks like ">l<"
2. No, you need to select a Mono track in cubase, which will play back equally on both the left and right
3. I have no idea
"That was so terrible, I think you gave me cancer!"
My tunage
Old 12-20-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
#3- You shouldn't have a problem deleting it. Perhaps you can try opening Reason on its own and delete it. Just a thought.
#4- Good man using the search function.
#5- Many folk here swear by Cubases all-in-one glamour, and do their projects from scratch-to-master-to-CD right in Cubase. So i guess the answer would be yes. But I, like most others here (I believe), prefer to use a seperate package for mastering/audio editing. I personally like Wavelab for my mastering duties. There are also packages like Sonic Foundry's Sound Forge and Magix's Samplitude (More $$$ for this one). When it comes time to burn the CD, Sonic Foundry's CD Architect, really is the cream of the crop on PC, thus making the Sound Forge package more attractive (Unfortunately Sonic Foundry decided to seperate the programs, when I was in the market to buy, hence I went with Wavelab, but I do believe they are included together again). You could of course go with a dedicated mastering solution such as T-Racks, which can be used stand-alone or as a plugin. There are many ways to go, it all depends on the money you're willing to spend.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 12-20-2005
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
I use Cubase for "mastering". Partly because I don't have a standalone wave editor, partly because I'm so used to it's workflow, I don't want to mess around with other stuff, and partly because I like to send it's output through my Kurzweil for using the KDFX compressors and EQs.
Think of how stupid the average person is, and realize half of them are stupider than that.
--George Carlin
Old 12-21-2005
Newbie
how do you master in cubase? i mean, what do i need to do to raise the volume of music i make so they will sound as loud as commercial mp3's or CD's?
Old 12-21-2005
scrubs's Avatar
Not of sound mind
Mastering is a complex process that requires great ears and a great listening environment/monitoring chain to determine what a mix needs. Typically, music is mastered by different people in different facilities, apart from where the music was recorded and mixed.
It is tough to get volume close to commercial cd's without serious skill and expensive equipment (at least, while still preserving the quality of the original recording). The mastering process typically involves some EQ, compression/limiting, and possibly some other tricks (stereo enhancement, reverb, etc.), depending on what might make the mix better. Download some Limiter plugins (the Kjaerhus Master Limiter is a decent freebie) and play with them. They will give you volume, but if you push them, your mixes will sound distorted and flat.
Basically, if you don't have the money for professional mastering (which would be preferred), you can do some things yourself, but the results may not be as satisfying.
My tunage
questions, questions, questions chronicinsomnia Newbies 8 12-08-2004 18:48
Specific Questions Regarding My Signal Chain MusicMan91 Newbies 2 12-26-2003 21:45
Questions about NWR. TheRealWaldo MP3 Mixing Clinic 8 11-15-2003 18:00
Please try the search before asking questions ola Other Equipment and Reviews 5 10-24-2000 02:09
