M-Audio Trigger Finger
Hi people, im new here and I just got a Trigger Finger and i have no idea what to do with it lol, im using it with fruity loops 5 or i also have acid 5, i installed it and everything, now how do i use it, i make hip hop beats by the way, http://www.soundclick.com/cabalisticakavenom
http://www.myspace.com/cabalatic1 |
Return it, get an MPD16, save 100$
Drum pads are just glorified midi keyboards so Pad 1 shoul be C1 (or C0). Just map the 16 pads in cakewalk to whatever drum machine/sampler you are using
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
so i cant just put any drum sample into a pad, i have to connect it to a drum machine/sampler??
You will need to hook it up to a sampler/instrument/something, it does not have any internal sounds
its usb, i cant just put a sound from my computer and assign it to a pad??
No, it is midi via USB. It is just a midi controller
so what else do i need in order o use it?
what does a sampler do and how much are they?
Its just to trigger the sounds in your software and nothing more.
i figured out how to trigger and record drums and snares and hi hats seperately on fruity loops, is there i way i can do em together?
#12
You dont need to make them together,in the end you need to seperate them anyway.
#13
"Gorty's Tunes" |
#14
What do you mean i have to seperate them anyway, i want to play the drums and snares together, it would be way to hard to play those separately and have them make the sequence i want them
#15
bump, please i need some help!
#16
man you shouldn't have bought something that you have no idea of how it works. That's all I wanted to say.
#17
Try this
When you record the drum tracks,asign every track according to their instrument.Say you have a kick on one track ,snare on the other and the hi hat. Now when you record it with midi(trigger finger) record all 3 tracks at the same time.When you are finnished open the kick and erace the snare and a hat from that track.Then open snare and erace the kick and hats, and the same for hi hat. So now you have 3 tracks playing together like they should. Thats the only way i can think of. Or just use the software that was provided with the trigger finger ![]() |
#18
#19
u know what is mpc? it's a sampler from akai, and it've got 16 velocity sensitive pads on itfor triggering the sounds in different volume according how hard your hit the pad. some artists like dj shadow and kut chemist use it for their show. Set the sampled sound into the sampler, assign the pads, and hit them in "real time".
That was for the performance on a stage, for recording, it give you a better feeling of controlling the beats with your finger rather than using a midi keyboard which are originally designed for triggering piano notes, u play it and record the sound just like you are playing a congo or bongo stuff. got it? |
#20
I knwo that, I know how to use, I just need to record drums and snares at the same time! how do I make a sequence with only one at a time!?!
#21
U don't. That was a suggestion. You record it just like any midi track, 16 pads at once if you want using your prefered sequencer and sampler
I reccomend recording slow (75 bpm or slower for hip hop) and speed it up later
#22
yeah but with FL 5 i only know how to record drums and snares etc. at seperate times, i need to know how to record both at the same time for a good sequence
if i cant record at the same time, then how can i make a sequence that lines up with the drums |
#23
not sure if I get totally what you mean, but here's my suggestion:
1 - Practice your control with the fingers on pressing different buttons at the same time. 2 - Use the metronome in fruity loops to help 3 - quantize the stuff (hope I'm giving you the right suggestion of the use of quantize) |
#24
Alright, I'm gonna break it down for you guys as basic as I can get,
With my Trigger Finger, I know how to do drums and snares seperately: So I can do... Drum..........Drum..........Drum..........Drum Then I have to do snares to be able to match up with it, which I have to do seperately so it doesnt come out perfect, so it looks like this... Drum..........Drum..........Drum..........Drum ............Snare....Snare...............Snare........Snare See how they're not all lined up, It's very hard to make them timed well together if I record them seperately, if I played that they would sound off, now if I could play them together, and have both Drums and Snares on different pads recording at the same time I could get them prefect like this... Drum..........Drum..........Drum..........Drum ........Snare.........Snare.........Snare.........Snare See I want them like this^, so that they sound perfect and on time with each other, if there is no way for me to be able to play drums and snares together, then how can I play them so that I can make em timed perfect with each other? I hope this helps anyone to help me... |
#25
Ok now i get it.
Like it was mentioned above,Play to the metronome.Its the thing that beeps when you record your music.Look in the manual and it will tell you how to turn it on. The second thing is the quantize,Its the button that puts all your messups in line.But its cant do miracles,if you are way off Hope that helps. |
| Project files dialog missing many audio files | Ptron | Cakewalk / Sonar Forum | 2 | 12-09-2005 16:09 |
| Audio to PC MIDI Sync | mark4man | Fostex Forum | 0 | 07-21-2002 08:45 |
| Audio to MIDI trigger | jgourd | MIDI Mania | 4 | 07-17-2002 12:58 |
| Help with set up! Audio Buddy | smalltowner | Other Equipment and Reviews | 10 | 12-28-2001 00:29 |
| N-Tracks and Audio Buddy questions | smalltowner | Newbies | 3 | 12-20-2001 11:30 |
