Old 12-13-2005
DavidK's Avatar
DavidK DavidK is offline
Ravel wannabe
DavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond repute
Moving tracks just slightly...
How do I do this?
I have imported a track thats maybe 1/16th note off, I need it to line up with my midi tracks. How do I "nudge" it over a bit? I think I know how to drag and drop, but it doesnt line up. Heres what I mean:
Old 12-13-2005
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
You probably need to turn off SNAP TO GRID - there is an icon above the track names on the left, but I normally just toggle it on and off again with the 'N' key.
Once it is off you will be able to click and drag it anywhere you want provided the start of the clip doesn't try and go further to the left than 00:00:00 -- it won't automatically trim the beginning...
Good luck!
Q.
<insert something witty here>
Old 12-13-2005
Dogman's Avatar
Dogman Dogman is online now
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Good luck!
Q.
Hey, I was just wondering this myself. Trying to line up a drum track with a pre-recorded song, and it was off just enough to make you cringe. Thanks, man. I'll do this and hopefully all is good....
I won the internets......
Old 12-13-2005
jpw23's Avatar
jpw23 jpw23 is offline
jpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond reputejpw23 has a reputation beyond repute
Good luck!
Q.
If you can't turn it off....like in gtp3......set it to 32'nds
If girls are made of sugar and spice....why do they all taste like anchovies
My music
G.F.C.G. 000 039
Old 12-13-2005
DavidK's Avatar
Ravel wannabe
Hooray!
Awesome stuff Q and the rest of yez. It does indeed turn off, you can just slide it over, worked great!
Old 12-13-2005
monty's Avatar
monty monty is offline
Banned
monty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond repute
It's been a while since I've used Cakewalk or Sonar, but I used to 'slide' a track forward or backwards. I recall highlighting the tracks I wanted to slide, then click one of the menus...maybe in edit or file...then it would ask how many "ticks" or measures. Could do a very small amount or any larger increment. Can always undo if you blow it.
Old 12-14-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Monty's got it right for when you need to make very small adjustments. Use the Slide command: Process > Slide. Positive integers move the clip right, while negative integers move it left.
I have Sonar setup for 960 ticks per quarter note, and the Slide command will allow you to move a clip by as little as a single tick.
Old 12-14-2005
DM1 DM1 is offline
Senior Member
DM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond repute
In sonar 4 (and I assume 5) you can also "nudge" using the numeric keypad. It works even when snap-to-grid is turned on.
Old 12-14-2005
monty's Avatar
Banned
I used to do it with one of two identical tracks to add a little something to the combined sound. Not enough to echo, but enough to alter the phasing.
Old 12-14-2005
DavidK's Avatar
Ravel wannabe
Good tips. I like the phasing suggestion, good call Monty
Old 12-14-2005
Yareek Yareek is offline
Dedicated Member
Yareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond reputeYareek has a reputation beyond repute
Yeah...I just turn off the snap, zoom way in, and drag the clip around with my mouse. I line up all of my tracks to the drum overheads to tighten everything up and reduce phase issues. Works like a charm.
For Sale:
Studio Projects C4 set - $235 shipped in the US
Presonus Firebox - $210 shipped in the US
AKG D112 - $135 shipped in the US
Rode NT2 - $275 shipped in the US
Beyer M201 - $135 shipped in the US
M-Audio BX8's - $275 shipped in the US
  #12
Old 12-14-2005
dachay2tnr's Avatar
One Hit Wonder
I've done that as well. It gives it a bit of a chorus effect.
However, nothing beats actually playing the same part twice.
  #13
Old 12-14-2005
monty's Avatar
Banned
Unless it's three times.
need help with V tracks on BossBR8 soundmaster Roland, Boss, VS Series Forum 10 01-31-2006 18:31
Hiding and showing tracks tombuur Cakewalk / Sonar Forum 1 08-05-2004 13:07
Audio tracks slightly out of sync kylla Cakewalk / Sonar Forum 8 04-02-2003 07:04
Studio Project B1 Recording... Robertt8 Microphones 34 03-30-2003 20:58
9 Drum Tracks in Two Days... remote drum recording... Blue Bear Sound Recording Techniques 58 03-01-2002 07:15
