Old 12-12-2005
ido1957's Avatar
ido1957 ido1957 is offline
4K Silver Member
ido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond reputeido1957 has a reputation beyond repute
How much will mixer affect separate preamp?
How much will my mixer affect a separate preamp? If I were to use a really nice preamp and then patch it into my mixer (Alesis Studio 24) to get it to my ADAT how badly would my mixer affect the sound quality - say if I leave the eq flat on the mixer?
G M P
H S B
Old 12-12-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
It is best not to run it into the mic input, you would probably be ok running it into the line input, though. If you could bypass the mixer altogether it would be the best, but I think that it only makes a small difference, as long as you aren't running through two preamp sections.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 12-12-2005
DavidK's Avatar
DavidK DavidK is offline
Ravel wannabe
DavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond repute
If it's quiet and doesnt add much noise you should be okay.
There is a better way to find out: test it. Try the pre alone then through the mixer. No better way to get the answer.
Old 12-12-2005
XLR XLR is offline
______
XLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond repute
I can tell a difference when I run a high quality pre through a mixer. It gets a little veiled. I'd always prefer to go direct from the pre to the converters unless I had to mix channels together going in.
Tim
It's easy to pose as an audio expert.
Do a background check... listen to their work.
Nice Preamp + Cheap Mixer? joshw Other Equipment and Reviews 1 06-29-2005 21:18
Mixer or preamp for more inputs? eswan The Rack 6 10-19-2004 09:09
mixer or preamp needed kidcrappyhead The Rack 8 05-25-2004 02:37
drum micing: mixer vs. preamp Barometer Recording Techniques 7 09-11-2002 01:18
Is a Mixer a Preamp? Is a Preamp a Mixer? moppet01 Digital Recording & Computers 2 06-22-2001 13:48
