Old 12-11-2005
oneup009 oneup009 is offline
Newbie
oneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of lightoneup009 is a glorious beacon of light
cable question
is the cable that connects the 1/4 in. preamp output to a recording device's 1/4 in. input the same as guitar cable?
Old 12-11-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
if they are unbalanced outputs, then a guitar cable would work fine....probably would work even if they were balanced outputs, but not sure on that one...havent tried...
Old 12-11-2005
Newbie
so should i use speaker cables?
Old 12-11-2005
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
Yeah- it's the same as a guitar cable.
Signal cable needs to be shielded. Speaker cable is not shielded.
Old 12-11-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Check the specs on your preamp. It probably has a balanced, 1/4"TRS (Tip Ring Sleeve) output and the input on your recording device probably has 1/4" balanced TRS inputs. Guitar cables are unbalanced, 1/4" TS (Tip Sleeve). So, ideally, you should be using balanced cables, but a guitar cable will work until you can upgrade.
"That was so terrible, I think you gave me cancer!"
My tunage
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
Mic cable question Purpleb Microphones 10 01-23-2005 23:48
XLR Cable question detuned6 Microphones 8 11-27-2001 10:36
A question about cable... Lame Thrower Newbies 4 11-23-2001 11:40
Cable Question Popcorn Newbies 21 03-11-2001 08:43
