Old 12-10-2005
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
making insert cables
when wiring up insert cables, what do you do with the ground? I assume you can just use balanced cable, split the pos. and neg. to the tip and ring of the TRS end, but what do you do on the two TS ends? Is there special insert cable with seperate grounds to positive and negative?
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen
Old 12-11-2005
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
Insert cables share a ground. I generally use shielded, single conductor cable for it (like coax) not because it's better, but because it's more abusable.
1/4"TRS ......... 1/4" TS x 2
T --------------> T1
R --------------> T2
S --------------> S1 + S2
T = tip, r = ring, s = sleeve. The left side is the stereo plug, and the right side are the two mono (TS) plugs.
I highly recommend you mark the output TS plug either by a different color plug casing, a band of electrical tape, different color wire, something, so at a glance you know which is the output, and which is the input on the insert cord. When you're in a rush you'll not remember. Even with coffee
Old 12-11-2005
Compression Addict
single conductor? Wont you need two conductors, (Tip and ring)? Im afraid im not following....
Old 12-11-2005
frederic's Avatar
Aaaah.
I don't count the shield as a conductor when refering to audio cables, but it's part of the circuit in this case.
Sorry 'bout that.
Who's making cables Big Kenny Free Ads for Music / Recording Equipment 5 11-15-2005 08:35
Using quality cables macca166 Guitars and Basses 11 06-05-2003 20:28
DIY Insert cables chingon The Rack 4 02-16-2003 14:23
who besides monster makes insert cables? kristian Other Equipment and Reviews 6 08-24-2001 11:36
insert cables j The Rack 3 05-19-2001 04:08
