Old 12-10-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
DIY Wire Tunnel
I'd thought about doing this a long time ago, but my new graphics card forced the issue. It's an NVidia 7800 GT (with a fan), sitting in my new PowerMac G5 quad. Everything else in the machine is quiet as a mouse. *sigh* The temptation to unplug the GPU fan is substantial, but I like my warranty....
Replacing the graphics card fan is probably next weekend's project. For this weekend, though... the DIY Wire Tunnel.
Project requirements:
1 x PVC Pipe, 2"
2 x Desk cable grommet, 2 1/2"
1 x phillips screwdriver
1 x roll of masking tape
1 x can of PVC glue
1 x hacksaw
1 x drill
1 x piece of coarse sandpaper
1 x board, 1/2"
1 x hole cutter, 2 1/2"
Steps:
1. Drill a hole through the wall. Try to line up the hole on the opposite side as much as possible.
2. Measure the distance from the outside of one wall to the outside of the other wall.
3. Subtract the inset distance for the inner part of the desk grommet. Subtract that inset distance a second time for the opposite end.
4. Cut the pipe to that length.
5. Take the phillips screwdriver and place it in the drill chuck. Using the drill, wind the masking tape around the handle of the screwdriver until the pipe just barely slips snugly over the resulting tape ball.
6. Using the board to apply pressure on the sandpaper, spin the pipe using the drill. Trim down the ends of the pipe until they will fit inside the desk grommet. (A sharp chisel may also be used.)
7. Insert the pipe into one grommet. Insert the center piece of the grommet and press until the pipe touches the center piece and the center piece is flush with the surface of the outer piece.
8. Insert this assembly into the hole and add the second grommet. Press this assembly together. (It helps to have a second person to push from the other side.)
9. Verify your measurements.
10. Push the pipe with one grommet out the other side, being careful not to change the angle of the pipe (assuming it isn't perfectly straight).
11. Trace a line around the pipe to align the grommet correctly.
12. Remove the grommet and apply PVC glue around the rim of the pipe.
13. Replace the grommet on the pipe, aligning it with the line you drew in step 11.
14. Wait for the glue to dry.
15. Reassemble things in the wall. Use clear tape to secure the pipe to the other desk crommet.
Congratulations. You now have a fairly nice looking wire tunnel.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 12-10-2005
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
nice, are you soundproofing this wall? caulk around the edges of the pipe where it meets the wall might be a good idea.
Got any pics?
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen
Old 12-11-2005
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
At first, I thought you were making a tunnel to go down the length of the wall.... say, a side wall from the front of your studio to the back, then I realized you're just going through the width of a wall.
The latter is much easier. To align the holes you use a long drill bit - the kind that looks like a giant screw. They have them in many sizes including 2". Just bore all the way through.
Old 12-12-2005
dgatwood's Avatar
It's not -that- loud. 61 dBA or so at 3 inches away, mostly wind rushing noise. The plain old wall does an adequate job of silencing it under normal use. Now when I ran the hardware test CD to check my new RAM... with all the fans spun up... no comment.
Got any pics?
Sure. Here ya go.
Old 06-28-2006
elenore19's Avatar
elenore19 elenore19 is offline
Slowing becoming un-noob.
elenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond reputeelenore19 has a reputation beyond repute
Question
Sorry, I'm a noob. But what was DIY stand for?
Old 06-28-2006
SRR's Avatar
SRR SRR is offline
BAKOVAB
Location: Everywhere a computer is plugged in and operating.
SRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond repute
Do it yourself
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy.
Equipment
G.F.C.G. # 000 035
Old 06-29-2006
pdlstl pdlstl is offline
Your daddy...
pdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond repute
If sound getting through this becomes a problem (ie: from tracking room to control room) stuff the hole with foam.
A Bass Drum Tunnel? Hubbawho Drums and Percussion 6 06-08-2005 11:27
which wire is which thomas1831 Microphones 1 06-06-2005 22:56
What Kind of Wire for L.E.D. Electronics? Inspired Guitars and Basses 24 05-25-2005 15:57
..soldering cables... "+" = red wire? "-" is black wire? earworm Microphones 5 05-14-2005 15:42
The Absolute Ultimate DIY Diffusor laptoppop Studio Building & Display 9 10-06-2003 19:44
