Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 12-05-2005
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
Weird output issues
Hey all
This might not by the right forum, but there's no Nuendo forum, so...
I'm using Nuendo 2. I have issues sometimes where my signals will come through the wrong tracks. Like if I have two stereo tracks setup, they both have the inputs as 1 and 2, and they're both sent to the master buss, I'll have signal coming in on both tracks, even though only the first track is record enabled, or even if nothing is record enabled. If I mute and unmute track two or fiddle around otherwise the problem goes away. But having this happen for even a second has caused problems, cause it's possible to have spikes like the ones caused by turning on phantom power come through my monitors. Obviously this is not fun. Any ideas?
Old 12-05-2005
iratecaller666 iratecaller666 is offline
Junior Member
iratecaller666 is a splendid one to beholdiratecaller666 is a splendid one to beholdiratecaller666 is a splendid one to beholdiratecaller666 is a splendid one to beholdiratecaller666 is a splendid one to beholdiratecaller666 is a splendid one to behold
hey
You'll get an answer shortly I'm sure. The higher-ups are fighting it out in the "Cubase Dongle Crack" thread that some lamer posted.
Are you absolutely certain that you're not forgetting to disable the monitor button on the tracks in question?
It's happened to me a few times.
Sorry if that was patronizing, just trying to help.
Tristan
Old 12-05-2005
corban's Avatar
Registered Boozer
I've been joining the fray in the dongle crack thread too.
Yeah, I work in tech support on the side, and I know you have to ask the dumb questions. It is definitely not set to monitor when that happens. I'll look at a track next to it that I'm not getting input through, and the settings are exactly the same.
Old 12-05-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Is that thread still going? What have I missed? I usually hit those threads in place of watching soap opera's
Old 12-07-2005
Pinachi's Avatar
Pinachi Pinachi is offline
I put the"s"in recording
Pinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond reputePinachi has a reputation beyond repute
/\ lol yeah its a big drama in there!
Old 12-07-2005
hueseph's Avatar
hueseph hueseph is offline
Dedicated Member
hueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond reputehueseph has a reputation beyond repute
It almost sounds like a hardware issue or an ASIO issue. Either way, I would try reinstalling your card drivers. It sounds like it's hanging when you change tracks. Just a wild stab.
All is vanity and a striving after the wind.
Old 12-08-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
What soundcard are you using??? Some soundcard control panels have an option to check that disables programs from directly accessing the control panels monitor section to prevent feedback loops and so forth. The software attempts to access the ASIO drivers through the control panels settings and override those settings with it's own, but can't do it, so reverts back and forth causing glitchy weirdness. Can't say if this the problem, but I have seen similar issues with a system running Cakewalk Sonar with an M-Audio Delta 1010. Once the Delta was set to ignore requests from the program, and deny it access to the control panel, it was fine (because Sonar now had direct access to the driver's). Just a thought, hope you figure it out.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 12-08-2005
corban's Avatar
Registered Boozer
Thanks guys. I'll have to check some of that out. It's a MOTU 24i I inherited. Any more advice is appreciated, I'm gonna have to try and hunt down the drivers.
creating two output mixes with sonar 3 chris857 Cakewalk / Sonar Forum 5 06-08-2004 18:40
audio output with cakewalk (soundcard) quagmire77 Cakewalk / Sonar Forum 7 04-09-2004 15:25
connection types baydariz The Rack 3 08-21-2002 10:41
knowledge share on my vocoding emerald tablet Recording Techniques 10 08-16-2002 12:40
Digi 001 output voltage confusion cordura21 Digital Recording & Computers 4 07-26-2002 15:53
