Old 12-05-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
condensed fiberglass info/where to buy thread
i'm trying to make this a one stop shop for fiberglass info, because wadeing through this crap sucks
feel free to add, but let's keep it as information heavy as possible.
Originally Posted by Diffusion
http://www.bobgolds.com/AbsorptionCoefficients.htm
Here you will find NRC ratings for just about any insulation or absorbtion product on the market... shows ratings for each thickness... thought this might help a few people out...
Originally Posted by pandamonk
Here is a list of Knauf coefficients i just got off the company
Absorption co - efficients - S = Solid Backing - C = Cavity
Rocksilk Slabs
Thickness RS33
125Hz 250Hz 500Hz 1000Hz 2000Hz 4000Hz NRC
40S 0.16 0.45 0.82 1.00 1.00 1.00 0.82
50S 0.10 0.60 0.90 1.00 1.00 1.00 0.88
60S 0.22 0.75 1.00 1.00 1.00 1.00 0.94
75S 0.24 0.53 0.89 0.94 0.96 0.98 0.83
100S 0.39 1.00 1.00 1.00 1.00 1.00 1.00
Thickness RS45
25S 0.05 0.25 0.55 0.75 0.9 1.00 0.61
40S 0.14 0.40 0.87 1.00 1.00 1.00 0.82
50S 0.25 0.65 1.05 1.10 1.05 0.95 0.96
75S 0.50 1.05 1.20 1.15 1.10 0.95 1.13
100S 0.80 1.15 1.20 1.15 1.15 1.00 1.16
50C 0.45 0.95 0.80 0.95 0.95 1.00 0.91
Thickness RS60
25S 0.10 0.20 0.65 0.85 1.00 0.90 0.68
40S 0.13 0.49 0.95 1.00 1.00 1.00 0.86
50S 0.25 0.65 1.05 1.10 1.10 0.95 0.98
75S 0.55 1.10 1.20 1.15 1.15 1.05 1.15
50C 0.45 0.90 0.80 0.90 0.95 0.95 0.89
Thickness RS80
25S 0.06 0.23 0.56 0.88 1.00 1.00 0.67
40S 0.14 0.61 1.00 1.00 1.00 1.00 0.90
50S 0.16 0.72 1.00 1.00 1.00 1.00 0.93
60S 0.25 0.90 1.00 1.00 1.00 1.00 0.98
75S 0.39 1.00 1.00 1.00 1.00 1.00 1.00
100S 0.59 1.00 1.00 1.00 1.00 1.00 1.00
Thickness RS100
25S 0.05 0.30 0.70 0.95 1.05 1.00 0.75
40S 0.12 0.44 0.88 1.00 1.00 1.00 0.83
50S 0.35 0.85 1.10 1.10 1.15 1.10 1.05
75S 0.44 1.00 1.00 1.00 1.00 1.00 1.00
50C 0.65 0.95 0.80 0.90 0.95 1.00 0.90
Thickness RS128
50S 0.40 0.90 1.00 1.00 1.00 0.95 0.98
50C 0.65 0.80 0.85 0.95 0.95 1.00 0.89
Thickness RS140
50S 0.40 0.90 1.15 1.05 1.10 0.95 1.05
Thickness RS200
50S 0.40 0.50 0.70 0.70 0.70 0.70 0.65
Rocksil Insulation Mat
Thickness
150 0.70 1.20 1.24 1.13 1.14 1.18 1.18
100 0.40 0.88 1.03 0.99 1.06 1.11 0.99
80 0.31 0.83 0.96 0.98 1.04 1.14 0.95
60 0.25 0.60 0.83 0.89 0.96 1.04 0.82
Rocksil Studio Mattress
Thickness
S= Solid Backing - C = cavity
Originally Posted by reshp1
Well as promised here it is....
Please post places that you know of to get rigid fiberglass, rockwool, mineral etc and the location of that distributer. If this thread gets big enough to be helpful, I'll try to get Dragon to sticky it for us.
I'll start
Detroit MI area,
Insulation Sales
Ferndale, MI
248-398-7200
"They carry Owens Corning 703 Unfaced, FRK (foil) faced and ASJ (white) faced in the 1", 1-1/2" and 2" varities." (thanks AjD)
Aurora IL
Amerisafe
http://www.amerisafe.net/store/item....ARTMENT_ID=152
Sells all sorts of fiberboard by Knauf (Owens Corning competitor)
NOTE: The website pricing is PER SQ FT, and they do ship via UPS anywhere in the U.S.
Someone posted a map of locations for a national chain that sells rigid fiberglass that I can't seem to find right now, but if someone has a copy please post that up.
Originally Posted by HapiCmpur
Got my Johns Manville 817 from McCormick Insulation Supply, Inc.
http://www.mccormickinsulation.com/
They've got a bunch of locations scattered across Maryland and Virginia. They were helpful, cheerful, and highly professional -- and that did not change when I told them I only wanted two packages of material.
Originally Posted by Milkman
I got some helpful information in a thread I started looking for some OC 703 or equivalent product in Canada.
Ottawa Fibre products, specifically the OFI-48 and OFI-64 (http://www.ofigroup.com/) are supposed to be extremely similar to the OC 700 series.
These OFI products are available through ISOFAB at several locations:
http://www.glasscellisofab.com/contact_us.htm
Originally Posted by fraserhutch
Paragon Pacific Insulation
(253) 872-0800
19710 58th pl S
Kent, WA 98032
Originally Posted by rpe
In the El Paso, Texas area:
http://www.selleinsulation.com/El%20Paso/default.asp
Got my OC 703 for $1.63 a sq ft. and they'll sell any amount (large or small).
rpe
Originally Posted by tapestry
For Atlanta:
The sheet is 2'x4'x2" and sells for $1.18 / square foot.
3287 Marjan Drive
Atlanta, Georgia 30340
770-454-9643
770-452-8637 FAX
800-633-5198
atlanta@spi-co.com
Originally Posted by savageblues
Just thought it might be of interest to someone, somewhere...
A good friend of mine works for Patene's which is a building suppy company here in Ontario. They dont rep Owens Corning, but they carry what he thinks is a similar product Roxul RXL40. A semi-rigid insulation which comes in 24x48" pieces of thickness 2, 3 or 4". Apparently their min. order would be one bag which contains 64, 48, or 32 sq.ft respectively. This is what I plan to buy when Im ready.
Originally Posted by Scottgman
I'm glad we've got the new guy here to straighten us all out on that issue!
Seriously, I'm no expert, but the data clearly shows that rigid fiberglass and rockwool do a pretty darn good job absorbing down to the 125 to 150hz range. I'm not sure what you consider the "low mid and bass range," but rigid fiberglass clearly does more than "reduce the reflection of upper midrange and high frequencies." Sounds like you are describing the performance of foam.
On Ethan's site, he explains: "705-FRK that is four inches thick and spaced 16 inches away from the wall can be quite effective to frequencies below 125 Hz." He also has data showing that higher density provides better absorption at the lower frequencies.
Check out Table 1 on Ethan's site (it lists absoprtion coefficients):
http://www.ethanwiner.com/acoustics.html
Check out Page 2 on this website for rock wool absorption coefficients:
http://www.fibrexinsulations.com/pdf...uationFire.pdf
I do believe that sealed bass traps like those described (and manufactured) by Ethan provide absorption below 150hz, but stating that rigid fiberglass panels only absorb the upper-mid and high frequencies is just plain wrong.
http://www.fibrexinsulations.com/pd...nuationFire.pdf
(once more for thoes links, so they don't get lost as a part of the overall quote.)
audio?
seriously, give me negative rep.
Old 12-05-2005
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
Good idea. For rockwool in Canada, (or possibly elsewhere) see www.Roxul.com The Safe n' Sound product is the best.
Old 12-06-2005
giraffe's Avatar
i love negative rep
roxl in NC
Dear sir - thank you for your recent inquiry. Below is a list of Roxul
distributors in North Carolina who MAY have the material you are looking for
in stock:
Triangle Materials Cary, North Carolina 919 469 2222
Colonial Materials Charlotte, North Carolina 704 392 0100
Life Safety Systems Inc. Indian Trail, North Carolina 704 347 5005
Atlantech Dist.Inc. Charlotte, North Carolina 704 391 0611
Lit Industries Inc. Gastonia, North Carolina 704 922 9851
Colonial Materials Inc. Pleasant Garde, North Carolina 336 674 1160
BWI Distribution Greensboro, North Carolina 800 599 5600
Specialty Prod & Ins Greensboro, North Carolina 336 691 0008
Alpha Insulation Charlotte, North Carolina 770 424 8600
Tucker Materials Asheville, North Carolina 828 684 5400
Ind & Commercial Insul Greensboro, North Carolina 336 274 1605
Specialty Prod.&Ins Wilmington, North Carolina 910 799 8444
Colonial Materials Stallings, North Carolina 704 821 9145
Insulating Services Charlotte, North Carolina 704 588 7814
Specialty Prod & Ins. Raleigh, North Carolina 919 828 7102
Boatwright Distr. Raleigh, North Carolina 919 832 1222
Building Materials Charlotte, North Carolina 704 504 3404
Specialty Prd.&Ins.Co Midland, North Carolina 704 888 4937
Colonial Materials Fayetteville, North Carolina 910 485 5099
audio?
Old 12-12-2005
giraffe's Avatar
i love negative rep
The insulation wont do much. Have a look here
The typical Brick Veneer construction with a layer of 10mm (3/8") plasterboard. This is the standard Australian house construction.
No Insulation 53
With Insulation 55
Brick Veneer construction with a layer of 16mm (5/8") plasterboard.
No Insulation 54
With Insulation 56
neat stuff
audio?
Old 12-17-2005
giraffe's Avatar
i love negative rep
Originally Posted by supertech1024
soundproof drywall ...Yes it does exist!
www.quietrockonline.com
This is the best overall solution!
the stuff is soundproof with just one sheet Comparable to over eight sheets of drywall.
this stuff has some special threads or something that convert sound to heat then there is a metal sheet laminated between the qypsum to stop the heat.
THX certified
check out the specs @ www.quietrockonline.com and don't forget to mention supertech I'm gonna need more!!!
thanks for the info on the doors too.
rock on
audio?
Old 12-21-2005
giraffe's Avatar
i love negative rep
Originally Posted by maardsma
This website ATS Acoustics sells rigid fiberglass board online (not Owens Corning brand, but equivalent). They ship to the US via FedEx which makes it easy.
I am affiliated with the site. I hope this post is helpful to those of you looking for an easier way to get the materials you need.
312132132132131
audio?
Old 12-27-2005
giraffe's Avatar
i love negative rep
Originally Posted by tubedude
audio?
Old 12-31-2005
giraffe's Avatar
i love negative rep
hes right... the max wall wont do anything for soundproofing... no foam will... to soundproof you need to use extremely dense materials... there is a product from auralex called Sheetblok which is used for soundproofing, but it is quite expensive... in the specs it claims to be "about 6dB more effective than a sheet of solid lead at stopping the transmission of sound." Anyway, hope I could help a little...
http://www.musiciansfriend.com/srs7/...se_pid/422611/
you might want to check this out too:
http://www.soundproofing101.com/soundproofing_2.htm
and this:
http://www.ehow.com/how_15992_soundproof-room.html
audio?
Old 01-03-2006
corban's Avatar
Registered Boozer
helpful thread here: http://homerecording.com/bbs/showthread.php?t=147777
I purchased useful panels to hold the fiberglass from www.modularacoustics.com, then purchased Roxul Safe n Sound from Home Depot. Very affordable solution, and good guy to work with.
Old 01-07-2006
giraffe's Avatar
i love negative rep
www.sensiblesoundsolutions.com
audio?
Old 01-10-2006
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Houston has this stuff CHEAP! :D
Here is the information of the guy I bought 4 panels of 4" thick mineral wool for 32 bucks!
Specialty Products & Insulation Co.
Russel Lea
Sales Manager
7210 N. Loop East, Houston, TX 77028
713-673-6200
www.rlea@SPI-Co.com
Was a really nice guy...
  #12
Old 02-07-2006
peritus's Avatar
peritus peritus is offline
"The Fountainhead"
peritus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond repute
From an old thread:
Originally Posted by notbradsohner
just wanted to let you all know..............
spi specialty products and insulations will sell you 703. you have to buy in packs of 12 sheets, which run for about 60 dollars. I just picked some of this up at the columbus, ohio store, so prices are from there
spi-co.com
Here's a clickable link...
SPI
P.S. Here's a map of their locations...
Cheers..
Joshua Dotson, Peritus Sound
SoundClick
  #13
Old 02-07-2006
emergencyexit's Avatar
emergencyexit emergencyexit is offline
Dedicated Member
emergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond repute
SPI didn't make me buy in 12 packs. They were fully willing to break open packs and sell by single panels. I happened to have bought 20 anyway though.
Ben
http://www.emergencyexitmusic.com
  #14
Old 02-07-2006
peritus's Avatar
"The Fountainhead"
Ben
Any price and thickness info would be awesome... Thanks
SoundClick
  #15
Old 02-08-2006
giraffe's Avatar
i love negative rep
i think 703 was about 1.15 a square foot?
many equivalent products are much cheaper.
1260 2" (51mm) A 6.0 pcf (96 kg/m3)
0.25 0.85 1.15 1.10 1.04 1.06 1.05
that's what i got, for about .60 cents a square foot
by comparison
703, plain 2" (51mm) on wall 3.0 pcf (48 kg/m3)
0.17 0.86 1.14 1.07 1.02 0.98 1.00
unfaced 703 is about twice as expensive.
audio?
  #16
Old 02-12-2006
peritus's Avatar
"The Fountainhead"
An off-site, but parallel thread: http://www.musicplayer.com/cgi-bin/u...6;t=001246;p=1
SoundClick
  #17
Old 03-06-2006
Kasey Kasey is offline
Force of Nature
Kasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond repute
this is a marvelous thread... im having trouble finding the pricings for a lot of this insulation though.
  #18
Old 03-06-2006
Force of Nature
which is better from Roxul, AFB or Safe?? you keep saying "safe n' sound"..but im not seeing that
  #19
Old 03-09-2006
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
Either is fine. I prefer the RHT80 for bass control duties.
I am serious... and don't call me Shirley
GIK Acoustics
  #20
Old 03-13-2006
Jonk Jonk is offline
Newbie
Jonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond reputeJonk has a reputation beyond repute
Hey everybody,
My first post here. Lot's of good info concerning where to buy rigid fiberglass and rockwool.
I'm out in California, a couple hours away from S.F. so I checked the SPI there and they're prices seem pretty high. The 8 pcf 2" 2'X4' panels of Roxul are $.70 a square foot.
I mentioned that I'd heard about someone in Oklahoma (Scottgman) getting it for $.39 a square foot, and the guy said that's lower than they get it at cost.
Anyway, does anybody know of a good place to get Mineral Wool close to the Bay Area? I'd even be willing to pay more that .39 a sq. foot, but I think I can do better than .70. I need a lot of it.
  #21
Old 03-18-2006
giraffe's Avatar
i love negative rep
Not sure if many of you guys know about this stuff, so I thought I'd let you all know. This stuff is called Ultratouch, and it is an evironmentally friendly cotton insulation made from 85% recycled denim. Acoustically, 3.5 inches of this stuff is equivelant to 4 inches of OC 703. At 125Hz it has an NRC of .97, and from 250Hz upwards its NRC is above 1.0. Also, this stuff is completely safe - it contains no dangerous fibers or particles and causes absolutley NO skin irritation whatsoever. It is 100% percent safe.
Not enough you say? Well, each natural fiber of UltraTouch is saturated with a natural fire retardant (borates) giving UltraTouch insulation a Class-A fire rating. UltraTouch also contains active mold inhibitors and acts as an excellent pest, mold and mildew inhibitor.
You can check this stuff out here:
UltraTouch
And here is a place you can order the stuff:
UltraTouch Prices
I have no idea what shipping would be like on this stuff, but if you go to the Bonded Logic website and click "Find a Distributor", just follow the instructions and you should be able to find a supplier in your area.
Just giving ya'll a heads up!
EDIT: Forgot to mention, in the prices link that I gave, the R-13 is a 3.5" thickness, and the R-19 is a 5.5" thickness.
stufffffffff
audio?
  #22
Old 06-29-2006
tone_aot's Avatar
tone_aot tone_aot is offline
1K Silver Member
tone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond reputetone_aot has a reputation beyond repute
How many fiberglass panels do you think i can make for $50? I was gonna spend $100 but i had some unexpected bills to pay. I wanna get the fiberglass panels first, and then i wanna get some auralex foam.
  #23
Old 06-30-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
(p.s. Giraffe you misspelled "where" in the title )
Do you think Safe n' Sound is best for panels?
  #24
Old 06-30-2006
giraffe's Avatar
i love negative rep
i think i paid .60 cents a square foot for (hold on)
1260 2" (51mm) A 6.0 pcf (96 kg/m3) 0.25 0.85 1.15 1.10 1.04 1.06 1.05
(it's rockwool)
at http://www.spi-co.com/servicecenterdirectory.mv
and it only comes in 2*4 pannels so...
you do the math.
p.s. i do reccomend the 1260
audio?
  #25
Old 06-30-2006
giraffe's Avatar
i love negative rep
click the very first link in this thread, and read ethen winters sight.
(link also in the first post)
audio?
*STICKY* Where to Buy Rigid Fiberglass reshp1 Studio Building & Display 110 09-17-2009 03:15
An antidote for GAS? jeffree Other Equipment and Reviews 21 04-22-2005 16:44
BUILDING A NEW DAW: What to buy and better yet, what questions to ask? 3des Digital Recording & Computers 16 06-29-2003 03:33
Should I buy a minidisc mixdown deck? Plz help. Dolph Newbies 1 06-23-2000 17:33
