Old 11-30-2005
Peetr3 Peetr3 is offline
Newbie
Peetr3 is on a distinguished road
Rack hook up questions and suggestions
Ok guys so I'm starting to build my studio and I have a few connection questions about hooking up my (soon to be) digi 002 to a Behringer Ultragain Pro 2200 mic pre.
First of all, how do I go about connecting a mic pre (or compressor or eq for that matter) to my digi 002 so that one or all of them work at the same time?
When I go to record am I connecting the microphone directly to the mic pre or to the digi002? If somone could explain the phsyical connection of all this equiptment to the 002 that would be greatly appreciated.
I learned protools on an Mbox so all my eq and rack unit stuff were just plug-ins. The physical things are new to me because I'm just starting to build my studio.
ok so also: Is it worth going out and buying an Avalon preamp? Or are there cheaper tube preamps that sound good for the professional quality recordings I am eventually shooting for?
Old 12-01-2005
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Mic>Mic Pre or Mic Pre/Compressor(combo)>Digi.
If you have a choice between Behringers best and Avalons worst, go with the Avalon. Yes, it'd be worth it if you can afford it.
Old 12-01-2005
sweetpeee sweetpeee is offline
Senior Member
sweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond reputesweetpeee has a reputation beyond repute
Hi Peetr,
I have both the digi 002 rack and a rack pre-amp (Focusrite TT) the Focusrite was less expensive than the Avalon I looked at and it had twin inputs,which I thought was a cool feature.
You didn't mention what type of mic you are using.I am assuming it's a condenser mic which would need the 48V phantom power.You can get this from using the pre-amps on the back of the 002 (I always connect them first before switching the phantom power on), or you can use a rack mounted pre-amp and use one of the inputs on the back of the 002 that DOESN'T have phantom power. Use on of the higher numbered inputs maybe #7 or #8.I don't have the rack in front of me at the moment, but If memory serves me,on the back pannel,inputs 1 thru 4 have phantom power. You don't need phantom power witha pre-amp.
So we are going condenser mic into the pre amp, take the preamp output into one of the non phantom powered inputs on the digi 002.
Hope this helps, J.P.
Old 12-02-2005
TommyJ1112 TommyJ1112 is offline
Newbie
TommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond reputeTommyJ1112 has a reputation beyond repute
FWIW, the preamps in the Digi002 are pretty decent... not blow-you-away quality, but very usable. I would probably take that Behringer Ultragain out of the equation and run the mic directly into your Digi002 pre's (inputs 1-4). Otherwise, you could run your mic into your preamp (then posibly through a compressor if you choose) then into inputs 5-8 on your Digi002. (The 1/4'' connections as well as the XLR connections for inputs 1-4 always go through the Digi pre's)
Old 12-02-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Start by using the preamps in the 002, and if you are not satisfied with them then add an external preamp later. Putting a cheap preamp like a Behringer in front of the 002 is just a waste of money in my opinion, you might as well just go with the internal 002 pres. If you want an improvement over the 002 pres then you need to spend money on something like the Avalon or other external pres.
http://www.misterpotts.com
Studio construction questions michaelq Studio Building & Display 6 09-13-2005 03:09
Need Help With Building My Rack!! _mat_ The Rack 17 06-04-2005 09:38
So Many Questions - Will anybody help Me... ravishan Keyboards and Sound Modules 1 01-12-2005 16:07
Tascam 34B questions... lo beam Analog Only 8 01-03-2004 15:04
Newbie Questions! MusicMan91 Newbies 15 02-17-2003 10:55
