Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-30-2005
Dalius Dalius is offline
Junior Member
Dalius is an unknown quantity at this point
Cubase & ReWire
Hi all...me again.
Anyway, I'm attempting to use ReWire with Reason & Cubase SE. Now, what I want to do is to make a drum pattern in Reason with Redrum. I then want to route that drums pattern to Cubase and record it onto a track there. I went to cubase.net to ask but no one there replies to me...and when they do, it's with an unhelpful comment like "read the manual", well I HAVE read the manual and I can't read anything there about how to record drum patterns from Reason.
Can anyone help me out? Help would be appreciated.
Old 11-30-2005
$a1Ty $a1Ty is offline
Junior Member
$a1Ty is on a distinguished road
do you mean record the midi or the actual audio?
Old 11-30-2005
Junior Member
either....if MIDI will give me the playback whenever i need it, and ability to export it to final mixdown, then sure.
Old 11-30-2005
Junior Member
i dont know about recording the midi, but have you got reason be controlled by cubase? do the reason channels show up on your mixer, cos if you hit record it should record the audio on a channel
Old 11-30-2005
kaufi kaufi is offline
Newbie
kaufi is on a distinguished road
in cubase you can't do an "internal record" like in Ableton Live. set your locators and use file-->"export audio". in the export audio window you can make a chek mark by "inport audio in project" or similary field.
excuse my bad english, sorry.
Old 12-01-2005
Junior Member
$a1Ty: yes...it is controlled by cubase. just not sure how to get the audio info for the drum machine from reason to cubase.
kaufi: i somewhat understand... so is there no hope? i really need drums, and i like redrum better then cubase's built in drum machine
Old 12-01-2005
Newbie
why you want to do an "internal record" of your drums? CPU hungry? I don't understand the sense. All should work with your settings. And don't forget: you can use 16 audiostereo channels from Reason to Cubase. (for example: channel 1 for your BassDrum, channel 2 for your Snare drum, channel 3 for hihats, ... and so on )
Please tell, maybe I can help
Me use NI Battery2 in Cubase (but as a VSTi, not Rewire) it works fine.
Old 12-01-2005
Junior Member
When I hit record, no MIDI information from my drum machine in Reason is being sent to Cubase.
I'm not sure if it's actually an internal record...Maybe I have the in/out settings on the MIDI channel in Cubase wrong? I have the 'in' set as Reason Redrum, and nothing connected as out...is that wrong?
Old 12-01-2005
Newbie
Midiinput in Cubase must be your Midikeyboard, Midioutput must be your VSTi in reason. If you push record on a midichannel in Cubase, you record your Midikeyboard (midinotes from your Midikeyboard). The cubasemidichannel send it to the reason vstichannel (your midioutput on your midichannel). Reason lead the audio back to cubase ("devices"--> "Reason" [or similary] you can choose how much audiochannels from Reason to Cubase you want to activate) " , but you can not record this audio. But you can use the "export audio" function, and do a check mark by "import audio in current project".
On the one hand, in cubase you can't do "internal record", on the other hand the export function ist much faster, because you don't have wait the whole playtime
Old 12-01-2005
Junior Member
Hmm....so you're saying I can't record without actually playing the notes on my keyboard? I just want to make the pattern in Reason and have it record that pattern....I guess it's impossible, eh?
Old 12-02-2005
Junior Member
here, i've made pictures to help you understand...
Here is my loop in Redrum, in Reason.
I want to record this loop, WHILE IT'S PLAYING, onto a track on Cubase.
My mixer in SE. As you can see, the Redrum IS being recognized by Cubase. However, I want it to be on it's own channel (Drums) and recorded onto it.
Does that help clarifty things?
  #12
Old 12-05-2005
Newbie
I know what you mean, but how I've said, "internal record" is not possible in Cubase, and what you want to do, is "internal record". There are some other sequencers out which can do that, but the best (and also the best after cubase) is ableton live. - maybe in CubaseSX4
you can get the Ableton Live5 Demo here: www.ableton.com
  #13
Old 12-05-2005
NationalSandwic's Avatar
NationalSandwic NationalSandwic is offline
Dedicated Member
NationalSandwic is on a distinguished road
kaufi's right. Live is the first piece of software that i've seen that allows you to choose another channel in that program as an input source. in something like cubase, the only audio inputs are from your card/desk...ie microphones, instruments, etc.
far as i can see, recording MIDI isn't going to help, cos you want the Reason sound, so forget about MIDI recording.
although i've never used it before, i think ReWire might be the way. read this: http://www.propellerheads.se/technol...tion=mainframe and give it a go.
otherwise, you need to patch the drums out of your machine and back in again using real cables. ReWire does this "internally"...it's like an audio transfer protocol, and Cubase SE does have use it. good luck =]
  #14
Old 12-05-2005
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Just put your loop markers around one bar of the drums solo'd and do an audio export
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
  #15
Old 12-05-2005
ShiverMeTimbers's Avatar
ShiverMeTimbers ShiverMeTimbers is offline
Newbie
ShiverMeTimbers is on a distinguished road
This is the way I've been doing it. You can also seperate your Reason drum kit into seperate pieces by muting and using audio export. Not sure if this is the easiest or most effect way to get the drum tracks down but it has been working for me.
I'ams what I'ams.
  #16
Old 12-05-2005
Junior Member
Aw damn...yeah, I guess the Audio Export IS the only way. Meh, i guess it will suite my needs for now.
I hope they add internal recording to a new version of Cubase soon.
Cubase, Rewire and Reason Electric Sugar Cubase User Forum 0 07-30-2005 13:37
VSTI and AA 1.5 Rewire Cubase? ukejammin Cool Edit Pro / Adobe Audition Forum 1 07-13-2005 21:51
Cubase VST 5 with Rewire 2.5 rouge2004 Cubase User Forum 3 08-17-2004 10:28
Reason Rewire to Cubase SX Rendering PG13 Cubase User Forum 5 08-04-2004 12:18
Rewire with Cubase gluvapor Cubase User Forum 0 06-06-2004 09:12
