Old 11-30-2005
Max Mediocre Max Mediocre is offline
Newbie
Max Mediocre is on a distinguished road
What do I do with this EH mic pre?
So I just got this Electro Harmonix mic pre, and I'm not sure how to use it. I have a firebox, and I plugged it into one of the firebox's preamps, then turned the gain all the way down. Problem is, there's hardly any signal coming through. I can turn the gain up, but then I'm using the firebox's preamp and what's the point of having another preamp at all? Also, I knew there were grounding issues but I thought they were solved by using balanced cables. I'm running a balanced XLR to XLR straight from the EH to the firebox, but I still get an annoying hum that's almost the same level as the signal. Does anybody know what the deal is? I'm not sure if my unit is defective, or if I'm doing something wrong. It sounds good, but I have to digitally boost the gain a huge amount (like 20 db) before I get a reasonable signal, and then that hum just comes up at the same time. I'm using an SM7, which I think is a fairly low output microphone, but the gain on the EH pre is at maximum.
Also, are the tubes supposed to look the same? One of them definitely glows more than the other, I'm not sure if that's normal or not.
Any advice guys?
thanks.
Old 11-30-2005
jkokura jkokura is offline
Force of Nature
jkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond reputejkokura has a reputation beyond repute
You shouldn't be plugged into the pre...go into the Line in on the back of your firebox...
Jacob
Upmixed Productions
Old 11-30-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
found thread
Did you do a search? There was a thread a while back about someone who had hum with their EH preamp, and they fixed it, although I don't remember what he did.
EDIT: Here it is: http://homerecording.com/bbs/showthr...ght=Preamp+hum
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 11-30-2005
XLR XLR is offline
______
XLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond repute
I don't know about plugging the EH pre's output into a mic input... I think I'd rather avoid running through two mic pre stages. And are you sure the phantom power is off on the firebox?
My EH pre's have a hot output and no problems w/hum. In fact they're remarkably quiet pre's IMO. The tubes do glow differently from one another on mine also.
I use the 1/4" output jack to monitor and use a balanced TRS plug/cable to a balanced input with no hum. Only way I can make them hum is by using the 1/4" output with an unbalanced cable, which I don't think it's designed to use.
Tim
Old 11-30-2005
Newbie
I did a search and found the thread about the hum, but I don't think I really understood exactly. So what I really ought to do is get a balanced XLR to TRS cable and run it into the line in on the back of the box? That makes a lot more sense than running two stages of preamp. Thanks guys, I'll try that out once I can get my hands on the proper cable. The preamp itself sounds really nice, just for the record. I was running it at full gain so it was probably saturating the signal a good deal, but that was pretty much what I was going for anyway. I'm pretty satisfied with the actual tone.
One more question: if I run it into the line input, and I want a saturated signal (with the gain knob at max), how do I keep it from clipping digitally once it hits the computer? I guess depending on how hot the signal is it may not be an issue, but I'm curious if this will be a problem.
Old 11-30-2005
Force of Nature
once you get the right cable going, post some examples of your music...I'd love to hear...
Jacob
Upmixed Productions
Old 11-30-2005
Walter Tore Walter Tore is offline
Force of Nature
Walter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond reputeWalter Tore has a reputation beyond repute
I get no hum with my 3 either. I go XLR out of the EH, to 1/4" on the delta 1010 box. I recorded one last night using the EH's, called - kind of a silent night. It is just acoustic guitar and vocal, and no hum. Walter
http://www.soundclick.com/bands/page...?bandID=157137
Old 12-01-2005
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
The firebox manual covers it, page 20. The firebox software mixer enables you to reduce the gain of the cards inputs meaning you can crank the EH pre without clipping the converters.
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time."
C. M. Burns
http://www.shuttleworths.co.uk/micloop.gif
Old 12-02-2005
Ben Logan's Avatar
Ben Logan Ben Logan is offline
Senior Member
Ben Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond reputeBen Logan has a reputation beyond repute
If you want a saturated signal, the best way to get this with the EH pre is to use the "buffer." For this, you'll need to use the 1/4 inch out, instead of the xlr out. Crank the left knob up to acheive some saturation, then "buffer" the signal volume with the right knob (lower it until you get a suitable signal to avoid clipping your hard disk). This knob combo is similiar to a "pre" and "post" on a guitar amp.
When you use the xlr out, the right knob doesn't do anything - you've probably already noticed this. I'm not sure why the buffer only works when you use the 1/4 inch out instead, but this is the set up.
Old 12-02-2005
4-Man Takedown 4-Man Takedown is offline
Senior Member
4-Man Takedown has a little shameless behaviour in the past
They do this so that the signal through the XLR is more discrete I believe. The 1/4" is mainly for monitoring purposes in my case, or I guess you could use it as you have explained, but I would rather have my signal not go through the buffer.
The EHX pre, definately needs to be used with balanced cables, whether 1/4" or XLR is doesn't matter as long as they are balanced.
Old 12-02-2005
Ben Logan's Avatar
Senior Member
Yeah, you're right 4-man. The xlr signal is more pure. I do like the 1/4 output for the ability to crank up the gain though. E.g. "crunchy drums," etc.
Forgot to mention: I love this pre! Biggest bang for my buck yet. Proud RNP owner too.
Review – Studio Projects VTB1 mic pre Dot The Rack 68 07-21-2007 21:29
Some random musings from a recent mic shootout . . . chessrock Microphones 38 11-05-2005 21:20
buying a new mic & mic pre B-Mac_DsP Microphones 13 11-05-2005 12:15
Mic Pre connections help Hiwatt Bob Newbies 11 06-23-2005 23:04
Mic pre and compressor use Middleman Mixing / Mastering 1 08-10-2002 07:17
