Old 11-29-2005
notCardio notCardio is offline
I walk the line
notCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond repute
SONAR HS4 pc requirements
Yeah, I've read the specs, but in the real world, is anyone using SONAR Home Studio 4 on anything less than a 3 GHz P4 with 1G ram? Just wondering if I could get away with using a 2.8 P4 w/512 M. For those of you who have used other packages, does it seem to need less or more juice than the others out there?
Thanks
Old 11-29-2005
LfO's Avatar
LfO LfO is offline
roar.
LfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond repute
I'm running Sonar 4 on a 1GHz 512 RAM box, and it chugs along fine. Of course, as soon as they release a new version, they obliterate all documentation for all previous releases, so I can't tell precisely what the minimum "requirements" are, but I THINK this is right about at them. It runs favorably compared to the older copy of Home Studio I'd been running. So, in short, I'd guess you sitting pretty.
EDIT: For clarification, I'm running "Sonar 4 - Producer Edition" - the naming scheme is getting strangley ambiguous.
Live with Passion
Old 11-30-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Thanks
Home Studio is like Sonar Lite. It should run fine on that machine.
Old 11-30-2005
I walk the line
Question
Is that a 1 GHz P4 or a P3?
And has anybody heard of anyone successfully using a Celeron? I'm thinking of a laptop too. And do you think any of these would limit my ability to use any plugins, or more importantly, a DXi softsynth with it?
And just for the record, I posted this here instead of the computer forum because I specifically want to use Sonar HS4.
Old 11-30-2005
LfO's Avatar
LfO LfO is offline
roar.
Its almost certainly a P3, though I'm not at home and can't check. I use at least a couple of softsynths in every project, and an average of about 2 effects on every track. When I get up around 35+ tracks, things start slowing down and dropping out. So, your limit should theoretically be higher than that.
Live with Passion
Old 11-30-2005
acidrock's Avatar
acidrock acidrock is offline
Purge's arch nemesis
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
Arrow
You could get by with half of what you've got.
Old 12-01-2005
DavidK's Avatar
DavidK DavidK is offline
Ravel wannabe
DavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond repute
I ran Sonar 1 on a Celeron 566 with 192mb RAM for Years.
I just got an AMD Sempron 1.8 GHZ 512 RAM, I am running SONAR 3 producer with great success. Current project is up to 17 tracks with plug-ins, no problems whatsoever.
Old 12-01-2005
I walk the line
Question Hey LfO
Sorry to sound incredulous, but you're running SONAR 4 Producer on a 1 Ghz P3 with half a gig of RAM, and your getting 30+ tracks, a couple of plugins on each, while simultaneously running a couple of softsynths? Really?
And that's 30+ audio tracks? Because I've got a machine just like that already that I got for something else that I assumed would be too underpowered to use any currently available CW products. What kind of soundcard do you have? Right now it has a SB Live drive in it, but I've got an M-Audio Audiophile PCI sitting in a box that I can plop in it. WinXP (not Pro, unfortunately) and Reason 1.0. I've got LiveSynth Pro that I want to install on whatever I put HS4 on.
You may have just made my day.
Old 12-01-2005
LfO's Avatar
LfO LfO is offline
roar.
Well, I made my post from work, and it turns out I did overestimate a bit - I'm at home now, so I'll give you the REAL skinny:
Intel P3 - 996 MHz
512 Meg of RAM
Win XP - Pro, SP 2
Example Project 1:
18 tracks total
8 tracks = 4 softsynths (MIDI and Audio track each)
FL Studio w/ 14 internal drum/sample tracks
StringTheory
Korg Legacy Polysix
Korg Legacy Wavestation
8 standard audio tracks
4 MIDI tracks
13 VST effects (mostly Sonitus EQs, compressors and reverbs) (also, there are a few more out there, but they're on frozen tracks, so I don't count them)
This project is at its limit - it chugs along fine until the 4th softsynth comes in 3/4 through the song - at that point it hiccups, and drops softsynths. This only started after adding the most recent, umm, maybe 2 audio tracks and 4 effects? Before that it could handle the whole shebang.
Example Project 2:
38 tracks total
4 tracks = 2 softsynths (FL Studio again, and Korg LegacyCell - currently "frozen")
6 MIDI tracks
28 Audio tracks
13 active (non-frozen) effects.
This one runs fine all the way through, but only after freezing the LegacyCell (which is a REAL CPU hog) and a couple of audio tracks. At most, 16 audio tracks are "playing" (by which I mean there is audio data present) at a time.
So, I did overstate my case, but the most sensitive factor SEEMS to be CPU (which you have no lack of), and I think this is pretty good performance for the minimum requirements.
EDIT: Oh, and I'm using a Lexicon Omega (USB 1.1) for audio, and MOTU micro lite for MIDI.
Live with Passion
Old 12-01-2005
I walk the line
Question OK, I don't quite get the math
Project 1:
You have 8 tracks from the (4 stereo) softsynths that you have recorded as audio. You have 4 tracks of MIDI from the 4 softsynths (I guess I don't really understand why you have audio AND MIDI from the same softsynth, but I'll save that for another time). The you also have 8 tracks of audio from other sources (guitar, vocal, etc.). That would make a total of 20 tracks-16 audio, 4 MIDI. So where did the 18 come from?
I'm not trying to be difficult, I'm just trying to make sure I understand how this all works. I'm not exactly what you'd call MIDI-proficient.
And this is what you're able to play while mixing down to two tracks on the pc, correct?
Old 12-02-2005
LfO's Avatar
LfO LfO is offline
roar.
When you add a softsynth, by default it creates two tracks (I think that's default - its what I've got it doing regularly, anyway) - one audio and one MIDI. The MIDI track is the input to the softsynth - it drives it by sending note, velocity data, etc. The audio track is the output of the softsynth - where you add effects and control panning volume like any audio track.
I guess I double-counted a couple of MIDI tracks - there are the 4 for the softsynths, and 2 others driving hardware synths.
Yep - these play as described in realtime - the second project without a problem. and the first as I described. With this much load, there are some delays in screen redraws - i.e., if you try to change the gain or pan on a track, it might take a second to happen - it keeps its priorities strait, though, and degrades this before it degrades audio performance.
Live with Passion
  #12
Old 12-02-2005
donger donger is offline
Junior Member
donger is an unknown quantity at this point
It depends on what your trying to do. I ran sonar 3 producer edition on a P3 550mhz with 256mb of ram. I easily ran 10+ tracks with eq on all of them and compression on most. Im not saying this is the best setup but I got by. When I got my P4 3ghz and 1gb of ram it open a whole new world of effects and softsynths. Actually being able to run a quality reverb in realtime was a blessing
  #13
Old 12-02-2005
I walk the line
Thumbs up Excellent!
Thanks guys!
One more thing, what sort or registration does HS4 use? What kind of hoops am I going to have to jump through to get it working if I put it on a machine that isn't connected to the net? Or what if I want to put it on a second machine (like a laptop) just to see if it'll run on it?
I guess I should have put this in a separate thread, but I figured WTF.
Thanks again.
  #14
Old 12-02-2005
DavidK's Avatar
Ravel wannabe
Wow, thanks for this tip
Something like this happened to me.
So, basically when stuff like this happens, I am approaching the limit, does that make sense?
  #15
Old 12-03-2005
LfO's Avatar
LfO LfO is offline
roar.
Cardioid: Sonar 4 only required the serial it was shipped with, if I recall . . . don't know about HS in particular.
David: Yeah, that's the impression I get from overloading my system too often
Live with Passion
Sonar 4.......some questions Magnum Cakewalk / Sonar Forum 25 07-15-2006 11:27
MTC and sync problems with Sonar and Akai DPS16 PhillipT MIDI Mania 3 01-12-2005 14:50
Sonar conking out after importing .wav's previously exported from Fruity Loops Khompewtur Cakewalk / Sonar Forum 3 08-18-2003 14:38
Sonar XL 2.0 only seeing 2 out of 4 channels from Delta alecxm Cakewalk / Sonar Forum 3 08-11-2003 10:43
SONAR Locks up! Help! Aaron Cheney Cakewalk / Sonar Forum 4 01-16-2002 16:40
