Old 11-29-2005
David Katauskas David Katauskas is offline
Supreme Master of Nothing
David Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond repute
Florescent Lighting
Has anyone ever noticed how loud florescent lighting is...??? I was listening to my condenser recently thru some cans and noticed a strange hum...couldn't find it. Then I realized it was the florescent lighting.
Now I'm changing everything over to incandescent.
SoundClick...geezer stuff [Acoustic Rock]
MySpace...enter at your own risk. [Metal Oriented]
Old 11-29-2005
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
Traditional fluorescent tubes have quite a bit of hum, particular if they use cheap ballasts. Most compact fluorescents however are very quiet. Incadescents will add a lot of heat to the space, which will require running your cooling and exhaust more (depending on your climate).
Old 11-29-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Yep. Especially if you put the compacts in cans with a lens over them. I'm going to use regular flourescents above a floating cloud for most tasks, then switch over to low-watt incandescents for critical recording. Be careful with dimmer switches, they can be a source of acoustic and electric noise as well. I bought some high-end dimmers a while back that are supposed to prevent such problems, but I haven't tried them out yet. Wiring the new studio is still a few months off
Old 11-29-2005
1K Silver Member
I would suggest skipping the regular fluorescents and going with the CFs above the clouds too. Or if you go with regular fluorescents get fixtures with high quality ballasts. It is the ballast that makes the hum.
Old 11-29-2005
Faithful Departed
They won't give the right effect--I mean aimed upwards, near the edge of the cloud, reflecting off the ceiling. As I said they will be OFF for tracking anyway.
Old 11-29-2005
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
If you really want flourescents, you can fix the hum easily enough.
Drill out the rivets for the ballest xformer, and chuck it. Go to an electrical contracting supply house and replace it with a hospital grade unit. It will probably cost more than the fixture did originally
Enlarge the holes in the lighting fixture, and install rubber grommets. Then re-rivet using cherry rivets, or machine screws with an aircraft nut. Tighten 1/2" turn more than hand tight.
That solves the vibrational issue, and the back-emf noise from the fixture into the electrical of the structure, which hits your equipment of course.
Noise cancelling breakers, and recording gear on a seperate breaker (or two of three or four) never hurts.
Perfect Lighting frederic Studio Building & Display 18 08-06-2006 00:08
12 Volt Halogen track lighting biggestmuff Studio Building & Display 3 02-07-2006 14:59
MIDI and lighting possibilities tangerine MIDI Mania 6 10-24-2005 14:29
who are interested in Lighting, please come in! ut-exhibition Other Equipment and Reviews 0 06-01-2004 20:57
Cool Studio Lighting Dom Franco Studio Building & Display 18 03-16-2002 22:41
