channel strip question ¿?
hello everyone!
im from Uruguay (the little country) and im in the plan od openning a small studio, since there are very little here. we will be specified in recording vocals for publicity and for music, but just vocals, so we plan to have only 2 channel of GOOD quality gear. since there is little market here, we cannot aford to try anything before ordering, and no one here has what we have in mind this is what we though_: -Presonus - Eureka -Focusrite - Voice master Pro -DBX - 386 the 1st 2 can be ordered with a A/D coverter, and the DBX already has it. the dbx has no proces, but has an effect loop, so well put there a comp and a eq. anyone has any experience with this items? what are the PROs and CONs of these? any help is very aprreciated! thancks Juan |
Are you doing voiceover work? If so, you might consider the Symetrix 528E. It's a standard in the broadcast industry.
http://www.symetrixaudio.com/index.p...ow1=&Show2=312
Eric Practice Your Mixing Skills! Mix Our Tracks in Your DAW! www.Raw-Tracks.com Online Mixing Forum |
Yup, what he said. I've used the Focusrite and the presonus and they were nice for awhile but as my ears heard more, they sounded like less. The dbx is not highly thought of however it does amplify a signal
In His Name Big Kenny |
The Eureka is ok, I own it and it still gets used on every session but not on every source like I first did with it. It's not bad for the price and the eq/compression are ok, nothing to really get excited about. It's a nice unit for the price.
I've used both the Voicemaster and the Symetrix. The Symetrix is a bit easier to set up. Both sound pretty good for the money, though I lean toward the Voicemaster.
Anthony Media Audio Productions - Voice Talent |
Hi dadodetres
But, as you already know, the DBX 386 is just a pre amp so you will then need to purchase separate stereo compressor and EQ units to add as inserts if you are wanting this type of control prior to the audio getting recorded to HD. For two channels of simultaneous recording in the one unit, with compression and eq included, may I suggest checking out the following channel strips: Focusrite Twin Trak Pro JoeMeek TwinQ (current edition, not the older one) Toft ATC-2 That's about all I can think of at the moment. Best of luck! Dags
I have suffered for my music, now its your turn. |
To add to the last, if you want just one channel of great mic pre plus eq and compression look at the toft EC-1... http://www.toftaudiodesigns.com/ec1.html
I think this is gonna be higher quality than the focusrite or presonus units...and to echo other people - don't even think about the 386. I was looking at one, and then I heard it and said no - it's like it could be good, but it isn't...like a old camaro that's awesome from far away and then you get close and see it's full of rust holes and dents...and the engine's been swaped out for a crappy 6 cylinder... Jacob
Upmixed Productions |
so the 386 is not a decent quality unit? (we were thinking on getting 2 for the 2 channel recording)
so what mic pre / comp / EQ / converter would you recomend me for a 2 channel setup ? |
not good, run away
| Best Channel Strip in the $500-$600 Range... | scarboro78 | The Rack | 80 | 06-08-2009 11:17 |
| Sansamp RBI vs. Channel strip | metalhead28 | The Rack | 3 | 08-09-2005 02:40 |
| Trident 4T Channel Strip Anyone?... | kidvybes | Microphones | 7 | 07-01-2005 15:03 |
| Channel Strip Question | luapleba | The Rack | 3 | 04-29-2005 20:11 |
| Preamp or Channel Strip??? | Blue Steel | The Rack | 8 | 03-07-2002 19:37 |
