Old 11-29-2005
chipwits chipwits is offline
Senior Member
chipwits is on a distinguished road
Need advice please: Bedroom Studio
My studio is stuck to the confines of my bedroom. It is a 11 x 11 approximately with a large bed, carpeting, and a desk. One wall has a large window with a pull down vinyl shade. Ceiling is flat (not vaulted).
My first question is, if I am micing instruments within 1-2 feet of the mic, how critical is the room? I know when I talk in this room, there isn't much echo. Next, do you think if I treated this room somehow, a bit, it would help much with the sound? I can't get carried away, but I guess I could add some acoustic type foam to some areas on the walls and temporaily hang foam over the window shade by hooks or something (when I am recording).
Heh, I am newbie, and pretty clueless. I could use some help. =P
Thanks,
James
Edit: Additional Note: I don't record bass. Just guitar, fiddle, mandolin and male vocals. Don't know if this impacts the need for acoustic foam or not. But I read somewhere that you need thicker foam for bass.
Old 11-29-2005
JazzMasterWil's Avatar
JazzMasterWil JazzMasterWil is offline
Dedicated Member
JazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond reputeJazzMasterWil has a reputation beyond repute
I can't be of much help (I'm new at this as well.) But, here are some links that have been helpful to me.
Amp Isolation box
http://www.jeffstrong.com/ampbox.html
Gobos
http://www.jeffstrong.com/gobos.html
Two Really Good Links
http://www.ethanwiner.com/acoustics.html
http://www.saecollege.de/reference_material/
Old 11-29-2005
Cheeky Monkey Cheeky Monkey is offline
Dedicated Member
Cheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the rough
I'm pretty new at this also, but I don't think the problem is as much micing instruments within 1-2 feet of the mic and getting good results inside your recording interface as much as what the room will contribute when monitoring and mixing to get your final result. Nearfield monitors help in this regard to take the room somewhat out of the equation, but a bad room will be a problem that without proper treatment will be harder to translate. I'm much in the same boat and I know I will have to treat my room.
If I'm way off in my advice, someone please correct me.
Old 11-29-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
you can use an old freezer for an amp iso box.
if you're gonna have problems it'll probably be on the violin.
that's the only instrument (from your list) that you really (seems to me) need to be able to get away from to get a good sound out of.
everything else you can close mic, and mostly just cut the room out of the equation.
audio?
seriously, give me negative rep.
Preparing for Studio Session .... need advice kflow77 Mixing / Mastering 7 02-22-2005 13:27
Home Studio Construction Advice. Help Needed! BigHighLonesome Studio Building & Display 26 02-12-2005 16:34
Advice on reworking my home studio deafen The Rack 5 06-23-2003 08:39
Reconstructing Studio... Advice Seeked... Sonixx Studio Building & Display 4 08-01-2002 07:06
The Big gap between The pro studio and your Bedroom. Audio Examples CyanJaguar Mixing / Mastering 15 06-19-2001 18:23
