VST Adapter Patch Problem
Everytime I rescan with 4.5.1 I have to go to Properties for each plug and re-enable it. This was not a problem before installing the patch. Anyone else have this problem?
I like Miles Davis and I like violins, but right now I need a Telecaster with Don Mare DonOcasters through a Deluxe Reverb turned up to 10 - almost a John Hiatt quote |
I hadn't realized there was a new patch.
I downloaded it, but your post has me hesitant to install it - particularly since I am experiencing no problems with the current patch. |
I asked this question over on the Sonar forum at cakewalk.com. Hopefully there will be some good advice. If you'd like to follow along here's a link -
http://forum.cakewalk.com/tm.asp?m=6...1&key=򞞘
Here's the answer from Noel at Cakewalk. I followed his advice and all is well. As a bonus, this version of the adapter does scan faster.
From Noel: Are you running SONAR 4.04? Check the folder defaults settings in the VST wizard. You probably have the default set to disable plugins. So when you rescan all new plugins are disabled by default if so. If its set to disabled, just toggle this setting in the defaults and this should stop happening.
Cool - thanks for passing the word!
Q.
<insert something witty here> |
| problem with amp | donkeystyle | Guitars and Basses | 8 | 04-08-2005 15:57 |
| VST Adapter doesn't work | Zona Mona | Cakewalk / Sonar Forum | 13 | 02-19-2005 12:02 |
| MIDI (VST) Loop Problem | Budo | Cakewalk / Sonar Forum | 5 | 01-20-2004 08:03 |
| Can anyone helpme with a little vst problem? | stealingsilver | Cubase User Forum | 6 | 10-29-2003 07:57 |
| Anyone got Sonar 2.2 XL, EXSP24, and Vst adapter 4.3 to work together?? | Teacher | Cakewalk / Sonar Forum | 2 | 06-30-2003 13:19 |
