Old 11-27-2005
Big Kenny Big Kenny is offline
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
What eq do you use for vocals?
That's pretty much it, what do you use?
In His Name
Big Kenny
Old 11-27-2005
Middleman's Avatar
Middleman Middleman is offline
Professional Amateur
Middleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond repute
Sometimes I use the hi pass on my Portico preamp to roll out between 150-300 depending on whether its a main vocal or background or male/female, not always however. I try to get it right going in and tend to build everything around the main vocal. Not a great fan of EQing things after the fact on the primary vocal. The best EQ is the right mic in my experience and so I spend some time with the singer to obtain the best sound from the mic locker.
That said, on occassion, I will either drop the UAD Cambridge or Pultec on the track to get things under control or for special effects. Sometimes I EQ with a compressor just to get the color of the box or plug in. 1176 is good for a little edgy fattening or sometimes a DBX 160. You have to be careful to match the speed of the source with the speed characteristics of the compressor or things can go mushy. Overall I'm going for a little midrange push to pop the vocal out of the fray when using a compressor this way.
Most of my EQing goes on around carving other things around the primary image I track on the vocal.
This is just a test
Old 11-27-2005
xstatic xstatic is offline
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Eq's on my D&R console. For software, Sonalksis.
Old 11-27-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Whichever one it's asking for. Sometimes it's hardware, sometimes it's a plug...
Grab a UAD rig if you don't have one already... Between the Pultec, the Cambridge and the Precision EQ, there isn't too much you can't do.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 11-28-2005
brandondrury brandondrury is offline
Newbie
brandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond reputebrandondrury has a reputation beyond repute
I find myself using a de-esser more so than using an EQ. In fact, I hardly ever find the need the EQ vocals. If I do, it's very lightly.
Brandon
Old 11-28-2005
xfinsterx's Avatar
xfinsterx xfinsterx is offline
Metal Dork Extraordinaire
xfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond reputexfinsterx has a reputation beyond repute
Well, i usually track with a light ratio of compression from the get go.
What else.......i high pass to 100-200hz depending on the singer.
Then i usually use the PTeqIII and trim out any offending fequencies.
I always do a steep lowpass to about14k.
At that point ill insert either Analog Channel 1, or waves Rvox...or both for compression.
Then ill set up 3 or 4 sends, and bus one to a verb, then another to a delay, and another to a crushing compresion setting, perhaps another to an eq that has the low pass swept to say 300hz for fattening things up, or ill go the other way and do a high pass send channel for added presence.
Also for reverb sometimes its nice to have one verb for reflections, and another all together for tails, you can get cool textures that way.
For death or screamy vox, i use dynamic mics. I usually track with a very heavy handed compressor, like a dbx. I actually WANT to hear the compression when i track heavy heavy vox.
This dosent mean its set at 10:1 though, its still only at 1:5 or 2:1 but with the threshold still dipping pretty deep into the signal.
Also when tracking these type of vocals its helpful when mixdown comes if you have double or triple tracked them.
Guess thats all i can think of right now.
EDIT> Ugh, im tired i just noticed the thread topic is What kind of "EQ" do you use.
I use ptIIIeq or UAD Cambridge.
Sorry about the ramble!
Chris Finster
Geomana on myspace!
Falcon Recording Studios
Old 11-28-2005
Rodger Hartlett Rodger Hartlett is offline
Senior Member
Rodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond reputeRodger Hartlett has a reputation beyond repute
i find a bit of low cut if it really needs it. Then dial in some air and 220hz for presence.
notch out around 2k if things get too squawky.
Old 11-28-2005
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
I try not to use any. When an acoustic guitar is present, I've boosted the vocal 1db at 2K and reduced the guitar there 1db, adding 1db at 800hz for the guitar and reducing 1db at 800hz in the vocal.
Sometimes I've also boosted the vocal slightly @ 10k for "air".
What do you do?
Old 11-28-2005
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
Kenny, has someone done the "Folgers challenge" and replaced you with Walters? Because i CAN tell a difference.
cheers,
wade
Old 11-28-2005
Whose Walters? (Not to be confused with Where's Waldo?)
In His Name
Big Kenny
Old 11-28-2005
I was most interested in what gear was being used. Outboard gear. Not technique or compression , but what parametrics are getting the most use
In His Name
Big Kenny
  #12
Old 11-28-2005
Thread Killer
i cross-referenced a Gearslutz reference, as many of us do time in both places. do a search over there and prepare to be amazed.
i know , and i can't help you aside from "i use the eq on my symetrix 528 quite often when tracking a vocal. it sounds very musical, and it's flexible enough to go from subtle to mangle and even on mangle, it still manages to sound good".
yes, i do eq on the way in (i compress on the way in too), and as i tend to track vocals last (and have already built the tracking/song around how i want it to sound), i can always manage tailor the eq to what'll work in the mix.
software-wise, i like the URS plugs a whole lot.
cheers,
wade
  #13
Old 11-28-2005
Kind of Newb slam eh? I can take it, I was just really curious as to what was being used. Hence forth , I will keep my questions to myself.
Eat Me!
In His Name
Big Kenny
  #14
Old 11-28-2005
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
When tracking, I never use any eq on the vocals. Why? Because there's always a chance that sometime later, the artist is gonna wanna fix one damn line in the song, and it's bad enough trying to just match the mic positioning and emotions and levels, let alone trying to get the chosen eq back again.
  #15
Old 11-28-2005
Thread Killer
Eat Me!
good grief, kenny.....no need to get all mad and whatnot. i was just pokin a little fun. *sniffle*
cheers,
wade
  #16
Old 11-28-2005
As was I, now move on Walters!
In His Name
Big Kenny
  #17
Old 11-28-2005
Thread Killer
great point harvey. i don't track a lot of vocals for "clients" that come back for fixes--they tend to be pretty happy with the first round......and if they do come back, they tend to want to recut the whole vocal track anyway. i really don't do a lot comping for clients--none of them want to spend the $$ that it'd take to have me sitting there comping a track. most of the client work i do is "demo" style, for lack of a better phrase--guitar/vocals "live" type stuff, aimed at getting themselves gigs and making a couple dollars on the side having something to sell at said gigs.
on my own stuff, however, i take meticulous notes, so recalling a setting is pretty close most of the time. hell, really, though, i have a far harder time getting a decent performance out of myself in the first place......so eq is a lot lower on my list of things to worry about going in than getting a compelling vocal take.
cheers,
wade
  #18
Old 11-28-2005
Thread Killer
LOL.....that's what *I* get for being too sensitive.
cheers,
wade
  #19
Old 11-28-2005
Thumbs up
Love ya man!
In His Name
Big Kenny
  #20
Old 11-28-2005
AllOrNothinEnt AllOrNothinEnt is offline
Dedicated Member
AllOrNothinEnt is infamous around these parts
The EQ3-D.
  #21
Old 11-28-2005
Thread Killer
Love ya man!
back atcha ol buddy ol chum.
tis the season, no?
cheers,
wade
  #22
Old 11-28-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
Kjaerhous (sp?) Audio Classic EQ. Yeah, yeah, I know.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
  #23
Old 11-29-2005
BJW BJW is offline
Force of Nature
BJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond reputeBJW has a reputation beyond repute
. . . the one in cubase thats on every track.
I'm more interested in singing in tune, though (which is usually a struggle)
click the link my my sig and listen to some stuff on the music page and tell me what you think of my vox, if you have a spare minute
-Brian
Brian Wahl Band Site | MySpace | CD Baby
  #24
Old 11-29-2005
Joel Hamilton Joel Hamilton is offline
Senior Member
Joel Hamilton will become famous soon enoughJoel Hamilton will become famous soon enough
Unless it is for a very weird effect, I dont EQ the vocal on the way in.
I will, however use a pultec EQP1R or manley massive passive, or any good passive, inductive coil based EQ.
If I really need the vocal to get "shaped" I will have an EQ before the compressor chain, and then trim at the console. Amazing how boosting the heck out of 12k on a Pultec, then compressing with a couple of compressors AND a de-esser, then trimming the EQ a little at the channel can really make for a great "sit."
Or not. Sometimes you dont need anything.
Joel Hamilton
