Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-26-2005
Gerald Cordier's Avatar
Gerald Cordier Gerald Cordier is offline
Newbie
Gerald Cordier is on a distinguished road
Cool Drum Maps
I don't understand how the philosophy of the drum maps in Cubase SX work.can anyone help with this problem?
[IR46]
Old 11-27-2005
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
Basically the idea is you associate a MIDI note with a drum name, so when you open a MIDI part in the drum editor, you see the drum name, which makes it easy to program drum parts. Instead of inputting C1, you're inputting "Kick Drum" for example.
Needless to say, you want to create the map so that it conicides the mappings in your sampler/drum machine/drum synth.
Think of how stupid the average person is, and realize half of them are stupider than that.
--George Carlin
Old 11-27-2005
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
To add on a bit more...
If you have a synth, chances are it has a patch called 'percussion' or 'drums'. Every note is associated with a different percussive instrument ie, you'll have toms, woodblocks of different pitches, snares of different pitches, symbols, gong, all that stuff. Well if you take the time to map out that patch, or are lucky enough to find someone who has already done it for you on the web, it makes constucting drum tracks by hand a whole lot easier. The name of the instrument for each key will be listed on the left so you can quickly tell your tympani from your agogo instead of randomly clicking your way up the map trying to find the right instrument.
It's not as essential if you can play your keyboard drum tracks realtime. I had a friend who knew his setup well enough he could construct some pretty decent drums playing realtime on his synth. He still would go back and add in extra's though.
It's time consuming to map it out yourself, but if you are hand constructing drum tracks it is a time saver in the long run.
Old 11-27-2005
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Its worth mentioning that most drum machines (and synths) made since the late 80's will conform to the GM spec so when making your own maps, you should try to conform to that at some level since it will make things easier to know all those assignments
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-29-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Drum maps are also used to convert note information, i.e.:
If you have a MIDI track that conforms to the GM standard, that you want to play on a device/patch that does not conform to the MIDI standard, you could program the map to convert incoming notes to output a new value (i.e. MIDI spec says that Acoustic Snare is MIDI note #38, but say your synth has a sound that you want to trigger instead that is on MIDI note #70, you program the map so that any incoming #38's are converted to #70's). Obviously it is beneficial to design patches to meet the GM spec (Or at least most of it), in case you later use MIDI files created specifically for one synth/patch with another synth/patch, but for the times when you can't, the Drum map will be your best friend.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 12-01-2005
Newbie
Drum Maps
Thanks a lot guys for really clearing things up for me. you guy are priceless.
at the same time,I want to clear things up a bit more by letting you all know that I'm working with the Korg Triton LE and the Roland Fantom X6 keyboards
in the event one of you owns or records with one of these boards,you can probably clear things up a little more.
Once again,
Thanks
you guys are priceless
[IR46]
Electronic Drum Set wakeupbomb Newbies 9 12-17-2004 09:13
Kick drum vs. Bass Guitar Round 1 Scottgman Mixing / Mastering 11 01-29-2004 04:50
sonar 2, drum maps, soundfonts!!!!!! girvan Cakewalk / Sonar Forum 4 02-13-2003 23:26
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
Drum Tracks: GT Pro vs. HS 2002 Bill Colbert Cakewalk / Sonar Forum 2 04-09-2002 04:54
