Old 11-26-2005
thethirdman111 thethirdman111 is offline
Newbie
thethirdman111 is on a distinguished road
Listening to recorded playback problem
hi
I currently run a recently purchased fostex m80 through a mackie 1604 vlz mixer. A the last owners tape was included and is still on the machine and the playback is very good. However, after recording on the first track and listening to the playback the signal is very quiet. If i turn the trim up,which i dont think your supposed to do on a playback channel, it distorts the sound.
Any ideas what the problem could be. Im sure its simple.
thethirdman111
111
Old 11-26-2005
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow Clean the head until it's shiny and spotless, like a mirror.
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Old 11-26-2005
peopleperson's Avatar
peopleperson peopleperson is offline
I'm so sorry.
peopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond repute
Do you actually see a proper level on that track once you've recorded it?
Here a douche, there a douche, everywhere a douche douche.
Old 11-26-2005
Newbie
no. no level to be seen.
111
Old 11-26-2005
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Assuming you've set proper levels to record onto the deck, it only leaves a few possibilities.
1 - The tape your recording on is not the correct formulation for the deck. Try a different roll of tape, hopefully some Quantegy 407 or 457.
2 - The internal calibration adjustments may be out of adjustment from a previous owners attempt to monkey with it. Follow the calibration procedure in the manual or get it done by a qualified service center.
3 - As A Reel Person stated, the heads might just be dirty and/or making poor contact with the tape due to back tension misalignment on the supply reel.
4 - You're recording French Mimes!
Cheers!
Old 11-27-2005
Arrow I'll take #4!
You have to make sure the tape is threaded properly, and is presenting the oxide side of the tape to the heads. It would probably surprise you how many people may thread the tape wrong.
Old 11-27-2005
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
And, just to amplify that, on Ampex/Quantegy tape, it is the brown side that goes against the heads, not the black side
Old 11-27-2005
Newbie
hi
The last owner's recorded material play but perfect on the tape. So that proves the play head fine. But when comes to recording when send a signal from the mixer, no led lights up on the fostex m80 recorder. So the record head needs cleaning?
Help
111
111
Old 11-27-2005
I'm so sorry.
You're not even getting signal into the deck. Double check everything before the machine, and also make sure you've got the right input selected. I don't know that particular machine, but if you have a selection between mic/line inputs, make sure that's set properly. If for instance you're putting a mic into a line input, you'll get nothing.
Old 11-27-2005
Newbie
Hi
The case has been solved! I had my 8 inputs going into line inputs instead of going into the 8 direct out inputs. However i did have the 8 playback inputs going to the correct next 8 line inputs. That was why the playback was good.
At last i can start making recordings!
Thanks for the help
111
Critique Some Music I Recorded! Confusitron MP3 Mixing Clinic 22 08-24-2005 14:27
vst instrument playback problem tyrone Cubase User Forum 1 05-18-2003 14:03
Cakewalk playback problem Danelectron Cakewalk / Sonar Forum 3 12-01-2001 03:17
Problems getting Aark Playback of laid tracks thru Headphones while recording audio bloozguy Cakewalk / Sonar Forum 10 10-26-2001 15:21
recording and playback problem Eddie N Cakewalk / Sonar Forum 0 07-17-1999 18:20
