Fostex M-80(no playback)
Hi!
I just got one and while it moniters fine, when i go to play what i recorded, i get no sound. I do hear the hiss and pressing dolby lessens the hiss so ,something is getting through... I'm using Basf Emtec 468 tape.... Jamie |
Let's take it step by step: 1) "arm" the track by pressing the track number. The track number lights up red (and you already got that). 2) Press rec key once to get a signal into the meters (You'll rarely need the "input mon" button). 3) Adjust levels (Sorry for including this obvious step.) 4) Now to start the recording press rec and *while holding rec down* press play. The light next to rec should now be red. This means it's recording. If the meters respond to your signal it's not enough; you have to see that red light indicator on. If it's not lit or green, then you're not recording! After recording 5) During playback you should see the meters indicating a recorded signal (bouncing up and down) so the recording is there and not just hiss. Now, you have to get the sound out of there. 6) Check wires (wiring)? 7) Make sure your desk is also receiving the signal OK (some meter activity there?). If so, cool! Hope this helps!
-P. K. |
| Getting Fostex X28H to playback!!? Help! | dsfii | Other Equipment and Reviews | 2 | 05-10-2005 06:15 |
| Getting Fostex X28H to playback?! Help? | dsfii | Fostex Forum | 1 | 05-10-2005 00:35 |
| Unexpectedly low volume playback - could it be the adapters? | WayStar | Fostex Forum | 3 | 09-05-2002 07:49 |
| Fostex FD-8 with Yamaha Qy700 | tokion | Fostex Forum | 1 | 01-18-2002 17:06 |
| VF16 interface function questions explained by Fostex | jvdw | Fostex Forum | 0 | 08-03-2000 13:26 |
