Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-24-2005
mark4man's Avatar
mark4man mark4man is offline
MoonMix Studios
mark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond repute
Software vs. Hardware Limiting
People...
Onto my final phase of CD production; & I'm now ready for adding a few decibels of RMS to my tracks...as well as adjusting the overall gain of various tracks for CD level uniformity...& have ran into a software "limiting" dilemma.
I'm using UAD-1's Precision Limiter across the stereo bus; &...as with all software limiting, peak intermodulation adds a tiny bit of breakup to the resultant signal. It seems like this happens even at high sample rates; & also when chaining together multiple instances of the plug at lower outputs (although this does seem to help.) I would imagine this happens even with well known plug-ins like the Waves L series Maximizers?
So...is there a serious advantage to going hardware in this case? A good solid-state analog limiter wouldn't suffer the same DSP maladies as their software counterparts, right? What are some good units; & could I get away with an inexpensive solution like fmr's RNC or the dbx166, or would I have to go to a hardware L2 or a Weiss DS1-MK2?
Thanks,
mark4man
[OR...is there a way to achieve total transparency using software?]
Old 11-24-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
If it was me, I wouldn't run my finished tracks through an RNC or low end DBX for the final "mastering". There are some good analog limiter/levellers, but the good ones again are quite expensive. The least expensive option that I can think of that would still be good quality is the Aphex Compellor.
That said, I think it best for what you are describing to stay digital. I used to own the hardware L2 and I felt it sounded very good. I didn't notice the kind of breaking up you are describing. I have found a plugin that I feel does as good a job as the hardware L2, and that is the WaveArts FinalPlug. Very, very clean and transparent, I suggest you check out the demo.
Old 11-24-2005
mark4man's Avatar
MoonMix Studios
Albert...
Thanks, man...good advice...I will check it out.
mark4man
BTW - Someone else told me to have a listen to Voxengo's Elephant...will check back in with an assessment.
Old 11-24-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
It's a given that you're going to lose *something* just from having the limiter active.
That being said - have you tried the "B" setting on the UAD?
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 11-24-2005
mark4man's Avatar
MoonMix Studios
John...
Glad you came along ! ('cause, I remember...you were a hardware man...then a software man...now a reborn hardware man...just the kind of input I need.)
No...but I'll tell you what I did...I chained two PL's together @ +.75dB each to give me a smoother +1.5dB; & it now sounds great ! A little rumbly on the bass, but still nice.
So...what does the "B" setting do?
Thanks,
mark4man
Old 11-24-2005
Makes the bass a little less rumbly...
Dongle Crack for SX 2 Hector_Osbert Cubase User Forum 935 05-27-2009 15:10
Software vs. Hardware zocochico Digital Recording & Computers 10 11-09-2005 19:02
HardWare / FirmWare / SoftWare designers for music related projects grass Digital Recording & Computers 0 09-15-2004 03:30
Hardware to software transition Progger Digital Recording & Computers 7 11-14-2003 15:45
Hardware v. Software Effects - What's the Difference? bongolation The Rack 15 06-21-2001 00:57
