Old 11-23-2005
bpr103 bpr103 is offline
Newbie
bpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond reputebpr103 has a reputation beyond repute
Stupid Recording Chain Question: pre->mixer?
I've got a Mackie VLZ with three usable preamps, the other three have a very loud hum when I put the trim up halfway. But the TRS line ins on these three preamp channels sound fine.
Now, if I were to get a good 2-ch preamp with balanced XLR outs to replace the damaged mixer pres, where would this go into the mixer? Would using the bad preamp inputs on the Mackie nullify the clean signals from the outboard pre? Put another way, could I just keep the Mackie levels at "Unity Gain" to keep the outboard preamp gain unaltered?
Thanks for the responses.
Old 11-23-2005
blueroommusic's Avatar
blueroommusic blueroommusic is offline
you want this big boy?
blueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond reputeblueroommusic has a reputation beyond repute
just get an take two xlr to trs cables out of the outboard preamp, and into the line inputs of the Mackie. that should get the job done; and yes just set the faders at unity, and control the level from the outboard pre.
Old 11-23-2005
Newbie
Thanks for the quick response. Now, that's service.
Old 11-23-2005
LemonTree's Avatar
LemonTree LemonTree is offline
Suck 'em and see!
LemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond repute
I'd run a line from the outboard pre direct to your recorder and another (if your pre has 2 outputs) to the line in of the mackie for monitoring
Lemontree Studio
Not bitter, not twisted!
Old 11-23-2005
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
Feeling daring...
It's sounds pretty coincidental that three channels are good and three channels are bad. Might be that there's a seperate circuit board for each three channel strips. Could be that you could reseat the second board and resolve your problem...
Just a thought...
Old 11-23-2005
Newbie
Interesting, Lemon. Is this because the Mackie might add noise to the recording signal? even if set to unity?
mofo - afraid of solder. I was thinkging that there's a break in the grounding chain in those three (2, 4, and 6, so the pres aren't sequential) or something. but again, afraid of solder.
Old 11-23-2005
LemonTree's Avatar
Suck 'em and see!
you want the most direct route to your recorder, as in Pre to tape, pre to hard disk, whatever. Anything you add inbetween will degenerate the source.
A lot of Pre's will have a balanced XLR output and a balanced or unbalanced output on TS or TRS jack. So, you run the balanced XLR to your recording device and use the other into the line in on your mixer for monitoring what you're recording. Keep it clean
Lemontree Studio
Old 11-23-2005
Could be a press fit... or ribbon cable... I'm not familiar with the interior of the mackie boards... their harddrive recorders are notorious for loose connections...
Did the problem just crop up out of nowhere, or was it after you moved the board... If you rap on the strip does it impact the audio?
Old 11-23-2005
Newbie
Lemon - got it.
mofo - the problem just cropped up after ten years of abuse in tikki bars. It's probably sand in the pots for all I know. I'll knock on it, see if that makes any difference., and I'll have a look under the hood, see if it's just something unplugged.
Thanks all for the replies. It's five o'clock somewhere, and somewhere is here. Happy Thanksgiving to those in the States.
Old 11-23-2005
LemonTree's Avatar
Suck 'em and see!
you must be east coast, just gone 10pm in scotland
Lemontree Studio
Old 11-23-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Which VLZ do you have there?
The only thing I would say is that you should plug the external preamp output into line inputs on the VLZ that *don't* also have preamps. This is because the line inputs on preamp channels are attenuated and then routed to the preamps, and then to the channel strip. So on those channels you don't avoid the preamps by using the line inputs.
stupid international power adaptor question for recording equipment.... alexis Newbies 2 02-10-2005 18:27
Simultaneous Recording question Mmil09 Other Equipment and Reviews 3 11-20-2004 13:21
computer recording setup question HalighALie01 Newbies 6 11-14-2004 13:14
Pre or Compressor in the signal chain - where? CTyankee Newbies 6 06-06-2003 09:02
C1 with Art Tube Pre Settings Question? George Parler Microphones 4 10-15-2001 08:04
