Is this easily replacable?
http://a.im.craigslist.org/es/NH/DPl...AFoBsF3F0A.jpg
look at the aux 3. Is this easiy to replace? Thanks! |
Yeah, if the only problem is the 1/4" jack itself, that'll be no problem to replace. You should be able to (or at least one used to be able to a couple of years ago, I haven't looked recently) buy a replacement jack from Radio Shack. There's really nothing special about the jack itself.
The jack just fits into place from the inside, and that hex nut around the outside just tightens down with a pair of pliers to tighten the jack to the chassis. Of course, before you fit the jack to the chassis, you'll have to solder the leads from the circuitry to the jack leads. Depending on the construction style, there will either be wires connecting the circuitry to the jack (the easiest to work with) or there may be rigid metal conductors. The rigid conductors can be trickier to work with, but you can just either connect them or replace them with sheilded solid core (typically not stranded) wire. This is, of course assuming that only the jack itself needs replacing. If there is more internal damage to that circuit, that's another story altogether. HTH, G. |
you can get that connector anywhere's Any Radio shack as stated. The bigger question is it balanced or unbalanced. You'll want to know and replace with same that came out.
People always seem to embrace the future then long for the past |
.G. |
| Can you rig the la-610 to bypass the 610 easily? | muse93muse | The Rack | 7 | 08-04-2006 21:46 |
| Is this easily replacable? | antispatula | Mixing / Mastering | 0 | 11-22-2005 18:46 |
| Confusion To Be Easily Settled | eyeoflayman | Newbies | 5 | 11-07-2005 10:51 |
| Small problem that should be able to be fixed easily. | spazmuffin | Newbies | 3 | 10-16-2005 06:24 |
| Is there a way to easily insert when tempo changes are involved? | VTmosaic | Cakewalk / Sonar Forum | 2 | 09-08-2004 17:40 |
