How to to gradually slow down the tempo (and pitch) of a section?
Is there any software out there that allows you to gradually slow down the tempo (and pitch) of a section of an audio clip? I am doing music for a movie and basically I am trying to transition into a song that is about a 1/2 step out of key. (I am using Nuendo)
If you want to use your idea, Wavelab has a function called Pitch Bend that can gradually change pitch, so maybe Nuendo has that as well. If you also need to change tempo, you could do a few successive Time Stretch operations on adjacent measures until you hit the proper tempo for the new tune. Or you could write a transition piece . . . |
to get renegade on the project, you'll need some kind of doppler emulation software. Then pass your stereo mix selection through it to see what you get. As to how much of a change, you'll have to experiment.
That can also be translated into software that emulates digital turntables (plugin). Similar effect, but not quite the same result.
Input from Orlando Lee Rosario Tracking and Mixing (C) The Cubian Dreams project (Frankie's first engineering project! I'm proud of him!) |
| working out loop tempo vs pitch | tollbooth | Recording Techniques | 1 | 10-06-2004 09:25 |
| Need Advice: Best Method of Tempo Correction w/o Pitch Change | Chris Long | Recording Techniques | 1 | 06-29-2004 06:50 |
| Does anyone know know of programs that slow down midis without changing the pitch? | FattMusiek | MIDI Mania | 3 | 05-20-2003 02:21 |
| HS2002: Solo Button & Tempo Ratio Misbehaving | BluesMeister | Cakewalk / Sonar Forum | 8 | 01-04-2003 05:08 |
| TWO QUESTIONS: Tempo / pitch change and SCRATCH ELIMINATION | backontrack | Cool Edit Pro / Adobe Audition Forum | 3 | 10-03-2002 18:32 |
