Old 11-20-2005
DavidK's Avatar
DavidK DavidK is offline
Ravel wannabe
DavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond repute
recording softsynths?
How do I record a softsynth?
I figgered out how to play back the softsynth, I want to record it. Like on an audio track, just like a "normal" audio track. The softsynth seems to be CPU-unfriendly, and I am assuming that if I just record it I can ditch the softsynth.
When I record a "normal" synth ( I have a Roland), I solo the track and press record, my synth is hooked into my firewire soundcard/interface. How do I record a softsynth? I solo the track, set up an audio track to record it on etc, no dice.
I'm frightened, hold me
Old 11-20-2005
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Bowman,
You do have a manual, no? Then there's also the SONAR Help system, ja?
To Convert Your DXi Tracks to New Audio Tracks:
1. Mute all tracks that you don't want to convert.
2. Use the Edit-Bounce to Track(s) command. The Bounce to Track(s) dialog box appears.
3. In the Source Category field, choose Tracks.
4. In the Channel Format field, choose mono if you want mono tracks, and stereo if you want stereo tracks.
5. In the Source/Buses field, make sure all 4 outputs are selected. This will create a separate audio track for each selected output.
6. In the Mix Enables field, make sure all choices are selected.
7. Click OK.
Old 11-20-2005
Bulls Hit Bulls Hit is offline
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
Another option is to route the synth out to one of your soundcard outputs, then patch it back to one of your inputs and record that on a new audio track.
What I also do sometimes is run the synth output thru my GNX3, and into the amp and mic it. That really dirties things up
Old 11-21-2005
LfO's Avatar
LfO LfO is offline
roar.
LfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond reputeLfO has a reputation beyond repute
If you're running a recent release (Sonar 4 or 5, I think) you can use the freeze function - it exists to solve the very problem you're having (freeing up resources), and simplifies the whole process considerably.
Live with Passion
Old 11-21-2005
DavidK's Avatar
Ravel wannabe
Originally Posted by AlChuck
Bowman,
I thought this place WAS the Sonar help system
Your instructions worked perfectly, danke schon
I had never really used a softsynth, never had the computer power before ( got a new puter). I installed a demo, check this out:
synful synth
Listen to the samples: some of them blew me away. The strings on the Beethoven quartet are stunning.
LFO, I am on Sonar 3 producer. No freeze function, but plenty of softsynths to play around with.
Old 11-21-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
$500!
They better be good. I'm really tempted to download the trial - but I am very afraid I will like it.
Old 11-21-2005
DavidK's Avatar
Ravel wannabe
Originally Posted by dachay2tnr
$500!
Yes, 500 clams is pretty steep. HOWEVER, some of the user demos are so amazing, it would be absolutely worth it if you were a serious composer. On the user demo page, check out the mp3s called Paganini and Le Syn Hot. That's gotta be worth 500 bucks to be able to do that, you would have to pay a real violinist 500 bucks to learn and record the Paganini thing.
Old 11-21-2005
dachay2tnr's Avatar
One Hit Wonder
if you were a serious composer < snip >
Ah, there's the rub.
So, is there software for a basement hack??
Old 11-21-2005
LfO's Avatar
LfO LfO is offline
roar.
Of course!
http://www.apple.com/ilife/garageband/
Live with Passion
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
Best Value Mic(s) for Recording Male Vocals/Martin Acoustics Aceboympk Microphones 20 02-14-2005 13:40
Delta 44 vs. Windows Recording Mixer. God help me. Shepherd Digital Recording & Computers 2 06-09-2003 07:39
