Old 11-19-2005
Siy Siy is offline
Newbie
Siy is on a distinguished road
Quick question on my new Tascam 414 mII
I'm really new to all this stuff, and have just got a tascam through the post. I wanna have a play with it before my band join me to try and descipher how to work this thing.
So, just a question, can I plug a guitar directly into the 'guitar in' socket, or does it have to go through an amp first?
I don't want to blow it up on it's debut!
Thanks,
Siy
Old 11-19-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
If you did try to run your guitar thru an amp first then, and only then, would you be putting the unit at risk. That 'guitar in' jack is meant for plugging in a guitar or bass directly...
Further questions might get better response in our 'Tascam' forum under 'User Forums by Brand'.
...now in HD.
Old 11-19-2005
Siy Siy is offline
Newbie
thanks,
I did notice the tascam forum but only afterwards. someone can move it if they take offence
Old 11-19-2005
jeffree jeffree is offline
1K Silver Member
jeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond repute
Siy, I used to use a 414 myself. Sure, you can run a guitar directly in, but the sound may not do much for you without some sort of processing. If you don't want to mic an amp, then using a small guitar processor (like a POD) will do wonders for improving your tone.
To improve the sound, I'd also recommend cleaning the heads before each session, demagnetizing the heads once or twice a year, using the noise reduction system, recording things as hot as you can, pushing the pitch (speed) control all the way up... and, of course, reading the short manual repeatedly.
Doing these things, I was satisfied with my results as long as I didn't bounce tracks, which really begins to add noise.
Good luck,
J.
Tascam 414 MKII 110/220V.. EddieVergunst Analog Only 4 08-08-2005 07:51
Tascam DA-38 Question Dj SoundStorm TASCAM User Forum 5 06-30-2005 14:34
Quick Tascam MH-40 question! studiodrum TASCAM User Forum 4 07-28-2004 06:38
Why mixdown to a separate cassette deck? (TASCAM 414 MKII) crzydrummerdude TASCAM User Forum 22 07-24-2004 21:05
Tascam 414 Newbie Here - Effects? Pepper249 TASCAM User Forum 27 01-02-2003 11:53
