MIDI input issues
First of all, I have n-Track 4.0.5. I added a MIDI interface that I borrowed from my dad and had it working with n-Track, but I had to give it back. Now whenever I hit the record button (whether of not I have any MIDI tracks) I get a message saying "Error openning MIDI In device". Nothing bad happens, but I have to click "ok" after hitting the record button, which is kind of a pain in the ass. Think my only hope is to set the prefs to default and put everything back where I had it (minus the MIDI stuff)?
I can't listen to that much Wagner. I start getting the urge to conquer Poland. |
I think in the File | Settings menu, there is a screen where you can disable the MIDI input device. Either that, or you are re-opening a project (sng file) that contains MIDI tracks pointing to your missing MIDI device. You should be able to switch them to the "Windows MIDI Mapper" (or something called like that).
SoundClick...geezer stuff [Acoustic Rock] MySpace...enter at your own risk. [Metal Oriented] |
I didn't see such a screen under file > settings, but when i was enabling/disabling the input clock sync I got the error repeatedly. That, however got me nowhere. These are new sessions I'm starting, and it still thinks I should have a MIDI device coming in. Thanks for the reply, I'll see if I can get my account to work over at the forums on ntrack's page.
Actually, it's "File | Settings | Preferences". Then click on the "Audio Devices" and make sure you have the correct inputs/outputs selected. Selecting only one of these usually does the trick -> "MME : Wave Mapper" or "WDM : Wave Mapper". However, you may also have DS or Aiso as options.
I just reset the preferences and it seemed to work. I tried changing the audio device to MME or WDM, but that didn't work either. Thanks for the replies though!
| MIDI guru needed elect drums soundfonts | wfaraoni | MIDI Mania | 9 | 06-19-2006 10:36 |
| Korg Triton into Digi 002 Rack | cayotic | MIDI Mania | 20 | 06-26-2005 19:49 |
| Midi track with Sonar & Audigy’s Interface?? | carlosfl | Cakewalk / Sonar Forum | 6 | 06-25-2005 11:16 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
| Midi and PSR 330 | Gumbylives | Recording Techniques | 0 | 07-04-2001 18:24 |
