minor tweeks, better results
What are some minor details you guys do in your programs to get a better recording. I really dont know how else to explain this but just any settings, recording technique. Whatever it is you might do to get a better recording on the instrument(s) you use. peace.
The best "tweaks" have little to do with the program you use.
Mic choice and positioning. Proper setting of levels. Once I master these (ha ha), I'll look for tweaks... |
ok, so what are some tips you can give in order to get to the point I can start tweaking?? Which adjustments do you make??
Are you asking about tweaks for recording, or tweaks for mixing? They should be viewed as totally seprate processes. For most recordists, there is very little to tweak "in the program" during recording. The only tweaks in the program for recording are generally selecting the driver, the bit depth, and the sample rate. Most agree that ASIO drivers are the best, that 24 bits is optimal, and that 44.1 khz is the sample rate that makes sense most of the time. Beyond that, the tweaks are more outside the program, setting optimal gain structures and tweaking any HW comp/limiter settings.
If you question extended to the mixing process, well that's a whole other big ol can o worms with tweaks galore, and much too broad a question. -RD |
| best results | Nick The Man | Recording Techniques | 4 | 08-26-2005 22:11 |
| here are some preamp comparison results | jnorman | The Rack | 24 | 05-20-2004 01:21 |
| Results of the 24-bit challenge | Ethan Winer | Digital Recording & Computers | 16 | 03-24-2002 19:05 |
| AT-4033, NT-2, AKG C-3000 Test Results! | Mike B | Microphones | 11 | 04-01-2000 18:26 |
