Old 11-16-2005
The Engineer's Avatar
The Engineer The Engineer is offline
Senior Member
The Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond repute
How To Handle an "Up and Down" Artist?
One of my boys that records at my studio always tends to get up and down while recording, he's not very level. Some of his words peak to around -2, but they average around the -9 level, then he has some real low words that are around -12 or -15db ... How would I handle that without overcompressing? I never use make-up gain, because everything raises and not just the low db's ... I'm not sure how to go about compressing his vocals .. any tips or help is much appreciated!
Old 11-16-2005
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
don't sweat it, keep the levels on the conservative side and don't let him clip, especially if you are recording at 24 bit. You won't gain anything by heating the levels up except maybe a nasty clip or two.
If it is varying too much at mix time, hit it with a little compression or limiting to even it up a bit. Most of all, if he is comfortable performing like he is and is getting good performances out, don't risk screwing that up by making him self conscoius about where his levels are hitting and trying to get him to correct them.
I'll take a great performance with a little less than perfect recording over a "perfect" recording of a stale performance any day.
Old 11-16-2005
ndycus1 ndycus1 is offline
Senior Member
ndycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond reputendycus1 has a reputation beyond repute
just make sure that he doesn't clip. and if you're using a DAW, you could easily go in and manually increase the levels of his quieter passages to make them more consistent with the louder ones.
Old 11-16-2005
Senior Member
Well I set a light compression during tracking and it doesn't seem to help much, and I don't want to over-compress while tracking and end-up ruining his dynamics. So little to none while tracking? then compress to my liking?
I'm recording to PC, by the way ... not DAW. I'm also recording at 16-bit because I'm too lazy to learn cubase or nuendo, so I'm still working with CEP 2.0.
Old 11-16-2005
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Automate the volume. I do this all the time.
Old 11-16-2005
Senior Member
How do I do that?
Old 11-17-2005
ez_willis's Avatar
ez_willis ez_willis is online now
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Punch him in the mouth and tell him if he doesn't start singing at a more consistant level you'll be forced to punch him in the mouth. Then kick him in the ding-ding so he knows you ain't playin'!
Originally Posted by 60's guy View Post
You win.
Old 11-17-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
I believe that a PC setup is generally categorized as a DAW. Not to be nitpicking or anything.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 11-17-2005
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
Get him to practice his mic technique.
He learns a useful skill as a vocalist, you're job is made easier- everyone's a winner.
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time."
C. M. Burns
http://www.shuttleworths.co.uk/micloop.gif
Old 11-17-2005
Senior Member
I thought like a Tascam FW1884 was a DAW. I thought DAW was like a digital recorder (hard-ware) I'm still new to terminologies though.
Old 11-17-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
It's a kind of nebulous term, it seems. Many folks refer to a DAW as a self-contained piece of hardware that includes I/O, mixing surface, and HDR all in one box. At the same time, many others refer to audio editing software used in a computer as "DAW software". Still others with larger studio configurations have referred to their Pro Tools subsystem as the "DAW" component of their studio
The way I figure it is that since "DAW" stands for "Digital Audio Workstation", it can mean any of these things and more. You just gotta figure how the speaker is using it in context.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
