Old 11-14-2005
exojjl exojjl is offline
Junior Member
exojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant futureexojjl has a brilliant future
tape deck ground?
A few things, I can get a good sounding recording of clean guitar, but distortion sounds horrible on my Teac A-160. On the back, there is a ground wire coming out (well the wire use to be there, I can reattach it of course). My question is though, where would i hook this wire at? Can I just ground it anywhere in my room? or to my amp? and would recording sound better if I grounded it?!
Old 11-14-2005
evm1024's Avatar
evm1024 evm1024 is online now
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
Distortion is not caused by the lack (or by) a ground. Distortion is typically caused by over driving an amplifier. So what levels are you sending to the deck?
Line in into a mic input will cause problems.
Grounds should all go to a single common point (in ac/mains or to a signal ground). With an improper ground you would get a lot of line/mains hum.
Regards
In Sunny Vancouver ..... (Washington)
Old 11-14-2005
Junior Member
im using RCA line in.
(in ac/mains or to a signal ground)?!?!?!?!?!??
Top 10 Reasons Demos Are Rejected... Robertt8 Marketing Your Music / Publicity 14 03-25-2006 13:32
Wilco's Jeff Tweedy on analog tape shortage Bigsnake00 Analog Only 10 07-22-2005 18:48
Well boys .... it looks like it's the end of tape ... for real now ... cjacek Analog Only 6 01-04-2005 11:05
Transfering 4 track tape to an external tape deck Michaelyu5 Newbies 8 10-22-2003 21:53
Panasonic Tape Deck oldradio Other Equipment and Reviews 7 06-25-2001 19:10
