Old 11-14-2005
TravisK's Avatar
TravisK TravisK is offline
Senior Member
TravisK is on a distinguished road
Sonar 4 is getting bogged down after 20+ tracks
Ok, so we are finishing up our EP today for my band, and it's sounding really great. But all of a sudden we seem to be running out of resources.
Even with every track frozen, we are still hitting between 40 and 50% CPU usage on a 2.2 GHz Athlon.
Even more interesting is that only about 10 of the tracks are played the entire time. The rest are simply leads or backgrounds or acoustic guitar. So it's kinda odd that they'd be killing the CPU as well if they aren't even touched during the majority of the CD.
Without bouncing tracks, are there any tips for getting more speed from Sonar? (And my dayjob is being a computer tech, so I know all about making Windows as effecient as possible)
I'm looking mainly for Sonar tricks. Hopefully Sonar 5 will help us out as we are using so many tracks because we need different effects on different parts, even if it's only a 20 second section. So with effects within clips, this would be about a 15 track operation.
Thanks again, you guys are always helpful!!!
One last thing...hahahahahaha!!!
Good Beef Studios
Old 11-14-2005
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
What is your soundcard latency set to?
If it's set really low, you could kick it up to 100 ms or so now that you're done tracking.
Old 11-14-2005
K-dub K-dub is offline
Force of Nature
K-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond reputeK-dub has a reputation beyond repute
This is good advice. In addition, look for a rogue plug-in that might be consuming unfair resource.
Just go through each track, turn each plug on/off, and see if there is improvement in the system. If a plug is consuming beyond its fair share, then you'll know immediately.
The system itself (inc. Sonar) shouldn't max out independently ... so two things likely lay at the base of the problem:
1) Problem w/ the hardware: (ie - latency settings for the sound card)
2) Problem w/ the transient software: (ie - look for problem plugs)
That's my two, hope it helps.
Best,
Kev.
My Albums are free at:
KevinWhiteMusic.com
Old 11-15-2005
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
I second the "lower the latency" concept of Strryder's -- I normally use one setting to track and another to mix.
So said, that track count sounds really low for you to be running into problems... Is this with the latency set at 4.5msec? Knock it back to 8 or so if that is the case and see if the problem persists.
How much free disk space, have you de-fragged recently or run the Cakewalk Audio Finder tool and cleaned up your hard drive, (backed up first of course...)?
Ciao,
Q.
<insert something witty here>
Old 11-15-2005
DigitalDon DigitalDon is offline
1K Silver Member
DigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond repute
Also, if you have the same FX running (with the same settings) like reverb, etc on several different tracks then bus them to the FX rather than having the FX assigned to each individual track. This will free up some CPU cycles.
DD
Old 11-15-2005
Pedullist's Avatar
Pedullist Pedullist is offline
Stop it, I can't breathe
Pedullist is on a distinguished road
Make sure you've cut or slip edit all silences (or people waiting to sing/play) in your tracks. So if you have a guitar solo somewhere in the middle: slip edit until the solo itself is the only part visible. It's a tedious job, but I found out that Sonar likes it better that way. It doesn't like processing lots of tracks with silences, plus it's still unnecessary hard disk activity. And plugins still have to process those silences, so it's a CPU saver as well. In my case at least...
http://www.nowhereradio.com/trojka
http://www.nowhereradio.com/trafo
Old 11-15-2005
Thorguitarist's Avatar
Thorguitarist Thorguitarist is offline
Senior Member
Thorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond reputeThorguitarist has a reputation beyond repute
woh woh woh....How do you change the soundcard latentcy????
Old 11-15-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Not completely sure about Sonar 4, but in Sonar 3 you have to use the "apply trimming" command to actually get rid of material that has been slip edited. If you just slip edit, the underlying material (silence) will still be there. Essentially it works something like a mute until you use the Apply Trimming command, at which time the material is actually deleted.
You can tell by reversing the slip edit. Initially when you slip edit, if you reverse you will simply get the original material back again. After you apply trimmming, you get nothing back but a solid horizontal line. So be careful.
Old 11-15-2005
dachay2tnr's Avatar
One Hit Wonder
Are you using WDM or ASIO drivers.
If WDM, you can simply adjust the latency slider in the Options > Audio control dialogue.
If ASIO, you have to do it through your sound card's mixing applet.
Old 11-15-2005
Pedullist's Avatar
In 4 and 5, when you slip edit the file is still there just like in 3, but it won't process the slip edited parts. I can clearly see the disk and CPU activity drop after doing some proper slip editing...so no need to trim.
It was the same in HS2004, so I assume it's like that in 3 too.
Old 11-16-2005
dachay2tnr's Avatar
One Hit Wonder
Yeah, I may have confused "processing" with "storage." In other words, if you want to reduce the file size by getting rid of all the slip edited parts, you have to Apply Trimming (after which they are gone for good!! ).
You could be right about the processing part - I would need to check.
  #12
Old 11-16-2005
Senior Member
I'm guessing this will work in Guitar Tracks also
  #13
Old 11-17-2005
acidrock's Avatar
acidrock acidrock is online now
Purge's arch nemesis
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
Have you archived unused tracks?
recovering tracks in sonar Chipster Cakewalk / Sonar Forum 4 11-14-2005 05:03
Click Tracks in Sonar 4 SE dave.m.stewart Cakewalk / Sonar Forum 1 05-29-2005 20:55
Weird Sonar 3.0 P.E - Loop Record Behaviour with Multi Tracks Qwerty Cakewalk / Sonar Forum 13 10-13-2003 11:50
question about backing up sonar audio tracks to cd stingray Cakewalk / Sonar Forum 3 01-04-2003 06:55
SONAR + DIO 2448 soundcard = my headache mime rifle Cakewalk / Sonar Forum 0 10-25-2001 11:15
