Old 11-13-2005
m. kong m. kong is offline
Newbie
m. kong is on a distinguished road
4 Track Maintenence
Does anyone have any info on 4 track cassette recorder maintenance?
I was going to give mine a bit of a clean and have been finding conflicting info on the net.
Is metho ok to clean the heads with? I've read that anything with a high percentage of alcohol is fine (metho has 97% from memory) but then I've read that you should use tape head cleaning solutions only.
Do you need to demagnetise the tape heads? I have a demagnetiser but have read that you don't need to use it on four tracks because there isn't enough magnetism created on the heads due to the thin tape and slow speeds used.
What is degaussing?
Old 11-13-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Degaussing = demagnetizing.
Once a year should do it for demagnetizing a cassette 4-track unless you use it every day -- then demagnetize it twice a year.
Be sure to use the demagnetizer far, far away from any cassettes you don't want to erase and store it far away too --- mine is on the top shelf of a back closet. When you demagentize, imagine that you are lifting a magnetic field off of the heads --- DO NOT touch the head with the demagnetizer, but sweep it slowly back a forth, then equally slowly pull it back as though you were pulling back an imaginary force field. Pull it back a foot or a foot and a half, then turn off the demagnetizer.
As far as cleaning the heads, I used high-percentage alcohol (NOT rubbing alcohol) and regular old Q-Tips. You can't over-clean, but you can over-demagnetize. I used to clean the heads before every time I sat down to record something. Remember, a cassette tape is only 1/8" wide so each track gets just 1/32" and a track that small can easily be adversely affected by even the smallest bit of oxide.
...now in HD.
Need help on recrding from my four track into my computer! bornmad Recording Techniques 10 08-09-2006 16:57
Playing To Other Recorded Tracks and Click Track. How? chapelhillbilly Recording Techniques 18 03-23-2005 12:15
Delete One Track from a Song? HD24 Scinx Alesis Forum 11 02-28-2005 16:59
Volume envelopes vs consol view- when do you use them? mixsit Cakewalk / Sonar Forum 7 07-17-2002 13:39
after track 1 recording...help ronnyron Cakewalk / Sonar Forum 5 07-01-2000 21:03
