Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 11-13-2005
sloom's Avatar
sloom sloom is offline
Dedicated Member
sloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond reputesloom has a reputation beyond repute
Unhappy US-428 and n-Track: Bit-Depth Issue?
I've been trying to work at 24-Bit, and I keep getting a Warning window telling me to be sure my soundcard is assigned properly concerning bit depth. The window(s) comes up several times, and then will play the tracks in the timeline window after I make them finally go away. This is a drag to do every time!
I'm using a Tascam US-428, which is a 24-Bit soundcard (24-Bit converters AD/DA). At 16-Bit, everything seems to be fine. I have the 24-Bit n-Track, though, and I've assigned the devices properly, far as I can tell:
I'm using WDM, at 24-Bit individual Mono tracks (not unpacked or justified- don't know what that is anyway). If I use ASIO, that brings other problems, WDM started off seeming to work o.k., but I don't remember what Bit-Depth I was using.... I think 24-.
I'd really like this to go away! Anyone have an idea?
Thanks for your time and expertise!
"Whatever we do, it is what it is, and we do it".
-the Grubs
Old 11-25-2005
sonnylarsen's Avatar
sonnylarsen sonnylarsen is offline
Dedicated Member
sonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond reputesonnylarsen has a reputation beyond repute
I can't speak directly to the Tascam, but I do have an M-Audio Omnistudio USB and If I want to use 24 bit I have to go into my soundcards prefs (an M-Audio Icon in control panel) and set it to 24 bit. This enables the interface to work at 16 or 24 bit. I would check the US-428's prefs to see if something similar is needed to work in 24bit
Sonny
Old 11-26-2005
sloom's Avatar
Dedicated Member
The US-428 does indeed work at 24-Bit, and you can set it up for this in n-Track's Audio Devices settings window- but I've been advised on the n-Tack forum to try using MME drivers instead of WDM. This has worked! 24-Bit.
I can't begin to talk about all these relationships within (this evil little box called) the PC... but there you go.
Thanks for the reply, Sonny.
-the Grubs
Us 428 Latency Issues in Adobe Audition MisterRob TASCAM User Forum 0 08-02-2005 08:57
