Old 11-11-2005
antispatula's Avatar
antispatula antispatula is offline
Force of Nature
antispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond repute
Questions on XLR and balanced and unbalanced
So I'm interested in XLR in more detail. So there are three pins; one of them is "hot"? what's that mean?
And one is "grounded"? What's that?
And I need to re-wire pins 2 and 3 because the unit I need it for is old enough to need a pin 2 xlr cable. If I re-wire the cable, can I use it for other things too? If I plug it in to a new mixer, will it mess it up, or just give no signal?
And I don't really get balanced and unblalanced. Just some general info on that would be great.
Thanks for helping out an ametuer when it comes to this kind of thing, even if you can only answer one or two of the questions!!
Old 11-12-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Google is your friend.
Here's what I found on my first try --- LINK!
...now in HD.
Old 11-13-2005
DonGraham's Avatar
DonGraham DonGraham is offline
Senior Member
DonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to allDonGraham is a name known to all
look at it as positive , negative and ground.....make sure you are wiring negative and ground together.....don't just go by pin number on the cord........some manufacturers like to switch pin configs..(Crest Audio comes to mind).......this should work on any XLR i/o.....you just won't get the benifits of a balanced connection.
Old 11-13-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
There is no real need to switch pin 2 and 3. You are just switching the polarity. If it is a mixer you are plugging into, everything you plug into it will be reversed, so it doesn't matter. Don't connect the negative to ground (pin 3) to ground. If your unit is old enough to have a backwards pinout, it might be old enough to have a balancing system that will fry if you don't send it a balanced signal.
In a balanced connection pin 2 carries you signal, pin 3 carries a polarity inverted copy of your signal (upside down if you were to see it) pin 1 is ground. In electronics, electricity has to travel a loop. Ground is the return path. (very simplified explanation)
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-13-2005
DonGraham's Avatar
Senior Member
I was just referring to tha fact that some older equipment is wired with pin 3 hot rather than the standard pin 2. In that case you would need to swap pins 2 and 3 or your signal would be phase reversed.
I don't know if that is what antispatula meant or not.
Old 11-13-2005
Farview's Avatar
Yea, but you told him to wire negative and ground together. That is a bad idea. It might not be what you meant to say.
Jay Walsh
Old 11-13-2005
DonGraham's Avatar
Senior Member
negative and ground would be tied together to make XLR on one end to a 1/4" unbalanced on the other........Yeah that could be taken wrong how I stated it though.
Old 11-16-2005
5ergo 5ergo is offline
Junior Member
5ergo is on a distinguished road
So if playing back CD its a unbalanced signal and balanced cables makes no benefit?
Does the cable quallity matter if connecting active monitors to a component such as Presonus central station?
What do you think of Klotz cables?
Old 11-16-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
The signal on the CD is unbalanced (no reason to store its mirror image), but it can be converted into a balanced signal with an electronic circuit. Pro CD players often have balanced outs to avoid interference over a long cable run.
To an extent, yes, but anything above the crap range should be fine.
Never seen 'em.
Old 11-16-2005
Farview's Avatar
Cable quality always matters, but the difference between mediocre and great cables is durability. Mid line cables will do fine as long as you don't move them a lot.
Jay Walsh
Old 11-17-2005
Junior Member
Thanks for replys!
I payed 4Euros/meter for cables i guess they should be fine for my setup.
XLR or 1/4" ... Balanced or Unbalanced ? mattkw80 Newbies 4 12-16-2004 08:01
1/4" unbalanced output to TRS or XLR balanced input DC-XPL The Rack 3 10-07-2004 08:40
Why does a TRS cable minimize noise? lirvala Newbies 20 08-02-2004 22:00
Cables: XLR vs. TRS, Balanced? guitar roy Microphones 15 05-06-2003 21:47
Balanced XLR to 1/4" unbalanced? omtayslick The Rack 1 03-18-2003 21:41
