question about line output
on my guitar amp, I tried using my line out by using a 1/4 to 1/8 adapter to my Y-cable that goes to RCA's so that I could use the line input on my tape deck to record. I can only record one channel!!! I get both channels though when i use the headphones port to record into the deck. Why is it that I only get one channel?!!?
The line output of the amp is mono, the line input of the tape deck is stereo, you are only feeding the one side.
its not possible to get stereo sound into my deck through the line out? |
You need a mono to stereo adapter, that will get sound coming out of both sides. That isn't stereo, it is dual mono. Your guitar amp is mono, there isn't much you can do to make it stereo.
my deck has two mic inputs, L + R which means i need two mics to record, so that means its dual mono (essentially stereo) ? Mono to stereo adapter? how does that work?
If you come out of the line out of the amp with a normal guitar cable (ts) and get an adapter (a 'Y' cable) it will split the signal to the left and right input. You are still listening in mono, just out of both speakers.
alright, so your saying if i hook a regular cable up to the amp, then use a 1/4 female to 1/8 female adapter, and hook my "y" adapter to it, that would work?
YOu would hook the 1/4 cable to a 1/4 mono to 2 RCA cable, hook that to an RCA to 1/8 stereo cable.
I chose those adapters because they are the easiest to find. You need to do two things. 1. convert mono to 'stereo' (it doesn't convert it to a stereo signal, it just routes one signal to both sides) 2. convert 1/4 to 1/8 Any combination of adapters that accomplish those two things will work.
since my tape deck input is two RCA, basicly i would cut the last cable, the RCA to 1/8.
That is it, you've got it.
sweet thanks.
| Question about Line 6 DM4 and Digitech RP50? | Fenderville | Guitars and Basses | 1 | 07-19-2005 08:30 |
| Balanced Output on V-Amp 2 ? and Sampling Rate Question | crgl | Guitars and Basses | 0 | 05-03-2005 17:11 |
| Question about ADA8000 and line input ..... | pcode | Digital Recording & Computers | 2 | 05-02-2005 20:18 |
| Mic-Pre to soundcard output question | Wingpen | The Rack | 1 | 03-25-2005 08:42 |
| KORG N-264 keyboard: High Impedance output or Line Output? | rgevol | Keyboards and Sound Modules | 1 | 02-21-2002 16:26 |
