Sonar and Reason
Can someone tell me how to integrate the two? I want to record vocals simultaneously with keyboard. Create a wav. I've been told you could run within the other. I need to know how.
Thanks,.. |
Sonar is going to be your host application - you need to add Reason as a ReWire instrument (ReWire is a communication standard for music programs, kind of like VST). Here's a bit of info (ReWire was actually created by the company who makes Reason):
http://www.propellerheads.se/technol...tion=mainframe I don't currently have access to my studio (that whole silly employment thing gets in the way sometimes), so I can't check exactly which menu its under, but you're looking for someting like "ReWire..." or "Insert ReWire Device..." - this could be in one of the menus or the DXi window.
Live with Passion |
What next
I added the Rewire device. So what's next? Do both applications have to be running. Or just Sonar?
Thanks,.. |
Still need advice
Still need advice. Surely someone knows how to do what I'm wanting to do? Record a track from my M-Audio keyboard and vocals at the same time.
Let me make sure this is what you're asking: You want to play midi in reason as you're recording vocals in Sonar?
"Trizza"
Maybe I'm confused, but I want to record in Sonar (while using Reason) both keyboard and vocals simultaneuosly.
I did as mentioned and added as a rewire device. But I don't know how to get it all to work together. |
Here's an article (from Cakewalk) on incorporating Reason with their products (its a bit old, but it should be basically accurate.
http://www.cakewalk.com/Tips/April03_AndertonPt1.asp After reading through here, you should know how to record a MIDI track (with output directed to Reason) in Sonar. I assume you already know how to record a standard audio track. From there, just arm both the target MIDI and audio tracks at the same time, and hit record.
Live with Passion |
Thanks,... I'll look it over and be back if I can't make it happen.
Kerry,... |
OK, I think you record the midi and vocals into Sonar, then you use Reason as a rewire instrument. So you would set the output of the midi track to reason, after you have added it as a rewire instrument. I think, someone please correct me if im wrong.
| Assigning Reason instrument/tracks to different channels in Sonar? | mbouteneff | MIDI Mania | 2 | 11-21-2004 20:53 |
| Assigning Reason instrument/tracks to different channels in Sonar? | mbouteneff | Cakewalk / Sonar Forum | 0 | 11-07-2004 18:06 |
| help using reason with sonar | michaelpayne | Cakewalk / Sonar Forum | 0 | 03-06-2003 12:57 |
| Midi controller, Sonar and Reason | cstockdale | Cakewalk / Sonar Forum | 3 | 02-03-2003 16:34 |
| Sonar 2 and Reason | johnhoe | Cakewalk / Sonar Forum | 5 | 06-09-2002 07:25 |
