Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-07-2005
hardcore guy hardcore guy is offline
Junior Member
hardcore guy is on a distinguished road
bottom snare miking
i love the way my snare sounds when i point an sn57 straight up on the edge of the bottom snare head. my problem, when i hit the kick, it rattles the snare wires. for evey kick hit, i get a very loud rattle from the snare mic. anyone know any tricks to tackle this?
Old 11-07-2005
systmovadown's Avatar
systmovadown systmovadown is offline
So cool for Shizza
systmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond repute
tighten the snare wires?
It's probably too loose.
Tighten it a little bit.
I had a problem with tightening mine so I duct tape the near end of the snares down..That baby shut it's mouth up.
Old 11-07-2005
Junior Member
i had the wires tightened so much that the snare sound was somewhat choked. it was still a problem.
Old 11-07-2005
So cool for Shizza
Try the Duct tape method on Post#2
Old 11-08-2005
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
You can also try wedging a piece of paper or a playing card between the snare wires and snare head.
Or try tuning your snare head up or down a pitch or 2. It might randomly be tuned to a sympathetic freq. with the kick.
-Chris
Old 11-08-2005
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
Is it a wood snare, or metal? What type of strainer is it? Quite often if its a buzz problem it has to do with how the snare wires are held in place, or how the bed is cut. Make sure the bed is centered well and isn't twisted so that one side is looser than the other. Adjust the snare wires or straps so that the bed is centered evenly.
A well cut snare bed is crucial on a wood snare. I always have the bed re-cut to a deeper level. That way the bed can rest on a slight curvature of the head. If you do this, you will hardley need any tension at all.
If the snare has one wire that is streched, nothing you do will fix the rattle! You will need to replace the snares. Run your finger across the snares while it is tensioned and see of one or more rattle. If it does, buy a new snare bed.
If all is well with the snare bed, then the problem is with the tuning of the rest of the kit and you have a frequency that is reacting with the tuning of the snare.
Another little trick for snare buzz is to tighten the lugs that correspond to the crossing of the bed (center of the head), and then detune the ones closest to the ends of the bed. This has worked wonders in situations where I can't solve the rattle problem.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
snare throw-offs zed32 Drums and Percussion 2 06-22-2005 21:19
shouldn't micing rhyme with slicing? mandocaster Microphones 65 05-11-2005 13:12
Need a better snare mic. Not happy with sm57 In Tune Audio Microphones 41 07-06-2004 10:22
Snare Tracking Recording Engineer Recording Techniques 27 01-22-2004 13:33
Miking Snare Played With Brushes crawdad Microphones 17 03-20-2002 07:51
