Behringer B1 for recording grand piano
Has anybody tried these mics on grand piano?
I am planning to buy two of them to record my 6' grand ( I play classical mostly). Thanks. |
Ok. What would you recommend?
(Other than MXL and Studio Project mics please, cause I am in Turkey and these are not sold here) |
What is your budget?
I'm hoping that if you have a grand piano, you can afford some decent microphones, but I could be wrong. I would look into a pair of mics, like Shure SM81, Neumann KM184, AKG C414BULS. Granted, those are much more expensive than the Behringers, but you'll want a relatively accurate recording for classical work, and the behri's cannot give that to you. On the cheap, I would recommend the Studio Projects C4 pair, but you can't get those. The Avenson STO-2 might be just what you are looking for, if you can find those in your region. A matched pair of those is about $500 US and they supposedly sound great. |
If you're willing to pay a bit for shipping you could always order Marshall or SP from online stores.
My budget is tight. (yes, sometimes you have a grand, but you don't have a $ grand )
Don't know why but Marshalls are not shipped outside the U.S. Haven't tried SPs though. Can you eloborate more on why Behringers are not suitable. Is it because they are large diaphram? |
Ok, thanks for clearing it out. I will ask if they have any NT-5s.
Your best bet for piano is usually a pair of small diaphram condensors. I've got a pair of the old AKG 451 EB, they're real nice on piano. The new ones will run you $500 apiece, but they'll be real versatile for you as well.
God this is ridiculous... the behringer B1 will sound as good on your piano as any sub $200 MXL or studio projects large diaphragm mic. It may break after a year if you don't take care of it... so take care of it but I don't think these people have even used it. If you have more money then there are other options... but the behringer B1s are made in the same factory as the studio projects line and I believe mxl products were made by 797 at one point as well.
For your budget, I would try a pair of the Oktava MK012. Pretty darned good mics for the $. |
#12
I'll second that. Sorry for posting a larger-than-budget recommendation, but I'll reiterate that a SDC is a better choice than a LDC, even if it's still a Behringer. I've heard the ECM8000 mics that scrubs mentioned are good, and depending on your room you might want to close mic it anyways.
#13
#14
They are not as accurate as small diaphram condensors though, and they will definitely color the source more. The Behringer ECM8000 is a reference mic and is supposed to be accurate.
#15
#16
Ok. I can find the Rode NT5, and will buy a matched pair.
Thanks all for the info. |
#17
#18
#19
![]() If you are buying something for PA use, there's probably not a piece of Behringer gear out there that wouldn't be good enough (assuming it doesn't die or something). If you are buying for studio use, though, you have to be much more selective. Behringer probably makes some good recording gear in much the same way that Nady makes some good recording gear. If you know -exactly- what you're looking for and research each available model very carefully, you can sometimes get reasonably good gear from either company. That doesn't mean that anybody sane should recommend Behringer's gear in general, in much the same way that one should not direct a blind man with no sense of touch or taste to pick an apple out of a barrel of rotten fruit simply because the first apple you grabbed was edible. A good manufacturer is a company like... say Mackie... where they might pick a piece of rotting fruit every so often, but it probably never made it into the barrel in the first place.
#20
#21
How about a pair of sE Electronics SE3's?
Are the sE Electronics mics available to you in Turkey? They run about $600-$700 US for a matched pair. http://www.seelectronics.com/ or in England http://www.sonic-distribution.com/2/...2_frameset.htm or check with Bob Reardon at Sonic bob@Sonic-Distribution.com <bob@Sonic-Distribution.com> Bob G. |
#22
For the price, I think you MUST try ECM8000. They are omnidirectional, the don't suffer proximity effect and you can put them into the piano without bass boost. Be aware of putting mic's too far each other, otherwise the piano image will be large as all the stage! It happend in a recording of mine...
#23
#24
Live with Passion |
#25
What's the qualification needed to give an opinion on sound? As long as your ears like what they hear then you qualify! I agree on the compressors, I often choose my Behringer over my RNC and Fatman, not always, but enough to come to the conclusion that it just sounds better on some things, simple as that.
| Behringer DDX3216 Digital Mixer | Berlingj | Other Equipment and Reviews | 39 | 08-06-2006 11:32 |
| Behringer mics | Ricklh | Microphones | 4 | 05-26-2004 02:04 |
| First impressions after some “nights with the Behringer DDX3216” | lukvdh | Other Equipment and Reviews | 2 | 08-01-2002 14:29 |
| Behringer advice please | MiXit-G | Microphones | 16 | 12-25-2001 10:35 |
| Behringer and Tubes | Rochey | The Rack | 15 | 11-30-2001 08:49 |
