Stereo recording - no phantom power
I'm trying to find either a pair of mikes or a single stereo mike to use with a portable minidisc recorder.
This is for recording my wife's live performances as a classical singer, usually accompanied by a single piano. At worst, I have to record from the front row seats - as this is in small venues (e.g. churches) the position is quite close to the performers but I cannot rely on having a mains power supply available. Therefore I need mikes that are either un-powered or can use battery power. We currently have one of those Sony stereo electret condenser mikes, but the sound is pretty poor and I'm looking for something better at around the £250 mark ($400?). As a guide, I could just about stretch to a Rode NT4. Any ideas? Thanks |
why are you focused on a stereo mic???for classical music, omnis are a much better choice(I am a singer, as is my wife,both of us are professional singers ) do yourself a favor and look no further than this:
http://www.soundprofessionals.com/cg.../item/SP-CMC-8 get these(pair), choose the battery box with bass rolloff, choose the "omnidirectional"element, and there you go. Instant compatibility with the MD. Also, I would STRONGLY suggest building a Jecklin Disc to mount these mics. It is the best way to record classical music, period. Plus SP service is great, and there is a coupon to get some extra% off the price. (type in taperssection in the coupon code area when you check out)I PROMISE you that for that budget you wont find anything better than what I suggested. I can build a jdisc for you if you want. pm me if you have more questions or email raytheapostle@yahoo.com Teddy Quote:
http://www.capitolflags.com/images/c...ebel-small.gif |
Thanks to both of you
![]() Teddy - I'm a little worried about using omnis on those occasions where I need to record from the front row (i.e. I don't have access to set up on the stage). I worry about picking up too much crowd noise - would that not be a problem for omnis? I'll look into this Jecklin Disk business. I'm sure they can't be too hard to make! Thanks again, Graeme |
Consider upgrading the Sony one point mic to a better SONY one point mic. I use Sony ECM-MS957 (about $250 in the U.S.) I've used it for madrigals with good effect, and it *does not* sound bad. It also has numerous studio applications for acoustic instruments and as a one point drum overhead.-Richie
You can also get the cardiod mic elements for them. Seriously though, for your application...those SP mics are the bomb, and work straight away with the MD.The battery box provides the power, and is smaller than a deck of cards. I will see if I can dig up some samples. I know all too well about these mics, as wife and I are both classical/jazz singers.Omnis do pick up some crowd noise..but the Jdisc negates that problem. of course any way you mount them will be fine, but the jdisc is second to none for classical recording.
Teddy Quote:
![]() If you have any samples, that would be great. Thanks, Graeme |
http://homepage.mac.com/jmfrench/iMovieTheater17.html
you are focusing too much on this "rear" sound. It is not going to be an issue. Thousands of recordings have been made in this manner, with omnis and a jdisc. One of the nice things about omnis is the transparency and capturing of the ambience. If you made a piece to go behind the mics, it would ruin the disc's purpose.. Just trust me on this. I have been in the classical music scene for 15 years, and have been around audio equipment for 20.
| Mic matching - Fact and Fancy | Harvey Gerst | Microphones | 39 | 03-28-2005 19:52 |
| Phantom Power Board Problem | Chris F | The Rack | 7 | 01-24-2005 01:22 |
| Using Acoustic Amp to Power Mic for PC Recording | Cheeky Monkey | Digital Recording & Computers | 1 | 04-21-2004 08:13 |
| Lexicon 284 Class A Recording Tube Amp | Pearldiver | Free Ads for Music / Recording Equipment | 2 | 08-02-2002 19:30 |
| SP T3 power supply + phantom power = kaloooey!? | spiral | Microphones | 13 | 03-26-2002 22:12 |
