Old 11-05-2005
ToneGrown ToneGrown is offline
Newbie
ToneGrown is on a distinguished road
Record Problem with Fostex R8
I own a Fostex R8 8 track and it won't record anything to track 8. the guy I bought it from said it played back just fine on track 8 but it just won't record. Any ideas, maybe an alignment issue?
Old 11-05-2005
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
Could be alot of things, Bad electronics, real dirty heads, worn heads, loose audio card on the inside Not sure about that one though not positive how the r8 is made inside. I have never had mine apart.
Could be a bad jack. Check and make sure your cables are good on that track.
Old 11-05-2005
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
I've heard that the R8 isn't screwed together, to cut costs. Apparently everything inside is held together with plastic clips, so it can go very strange when transported. But I don't have one myself.
problem with amp donkeystyle Guitars and Basses 8 04-08-2005 15:57
problem w/ the Fostex B16 1/2" 16 track dquinn Fostex Forum 4 05-21-2003 15:28
Asio 2.0 problem sodapopinski Cakewalk / Sonar Forum 13 04-25-2003 20:20
Problem with pitch Fostex B-16 F_cksia Analog Only 6 03-05-2003 16:20
Record Problem!!! ALEXUS09 Digital Recording & Computers 2 05-17-2001 05:20
