Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-05-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Drum throne that doesn't squeak?
I keep getting annoyed by the cheap throne that came with my set. It squeaks at the slightest motion. I've added some felt in certain places to reduce it, but it still sometimes squeaks annoyingly.
Every throne I find in web store searches either has nearly zero customer comments or has a comment about it squeaking. Thus, I figured I'd ask here....
Can anyone recommend a throne that doesn't squeak?
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 11-05-2005
systmovadown's Avatar
systmovadown systmovadown is offline
So cool for Shizza
systmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond reputesystmovadown has a reputation beyond repute
theres the tama one ... it goes out for 30 bucks its pretty good.
if u dont care how much u spend...theres
http://www.musiciansfriend.com/srs7/...se_pid/440791/
THE MOST COMFORTABLE thing in this world.
Old 11-05-2005
JonathanRay's Avatar
JonathanRay JonathanRay is offline
Senior Member
JonathanRay is on a distinguished road
You should use some WD40. I use on my throne to stop squeaking.
- Jonathan
Old 11-05-2005
dgatwood's Avatar
In my case, it's more of a groaning, squeaking, clanking, and various other things. Ludwig really didn't make this thing well. It's a center shaft inside another center shaft with NO rubber gaskets to support it. Metal on metal, with an air gap in-between. Oh, and it is supported by something that looks like a carriage bolt. Makes noise around that, too.
When you rock the top, it shifts a quarter inch with ease, and makes LOUD noises. It's sad when you can hear the throne cutting through the cymbals....
Basically, it's so far from a decent design for recording that it isn't even funny. If I were gigging with the thing, it'd probably be perfectly fine, but... for recording... hopeless.
Kick Drum Miking Question zackformula Microphones 18 06-22-2006 07:28
Drum throne height Cobra67 Drums and Percussion 4 05-04-2005 11:58
3 Drum Map Queries ebitda Cubase User Forum 2 07-07-2004 13:32
Cheap drum triggers/pads Lopp Drums and Percussion 7 04-09-2003 22:58
Drum Tracks: GT Pro vs. HS 2002 Bill Colbert Cakewalk / Sonar Forum 2 04-09-2002 04:54
