Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-03-2005
Drummyjoey Drummyjoey is offline
Junior Member
Drummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant futureDrummyjoey has a brilliant future
Does anyone here know how to tune a drum?
I just can't get it. I want to do it by ear, but I feel like whenever I turn one lug, the rest all change in pitch as well. I can make it so one is all the way loose and the rest very tight and there is minimal difference in pitch. What gives? Any help is appreciated.
Oh, and PLEASE don't refer me to the drum tuning bible...I found that to be no help at all.
Old 11-03-2005
Junior Member
Oh man, I think I just had the best idea. If it works out I will definitely let you guys know...
Old 11-03-2005
funkdrmr funkdrmr is offline
Senior Member
funkdrmr has a spectacular aura aboutfunkdrmr has a spectacular aura aboutfunkdrmr has a spectacular aura about
Take both heads off.
Place the drum top down & start with the bottom head.
Place the head onto the drum, line it up how you want if you're that picky (I am!)
Put the rim on top of the head, and tension each lug as tight as you can with your fingers....I only use one hand to tighten, so I know they'll be as close as I can possibly keep them. Also, make sure you follow the correct pattern around the drum, to keep tension even.
Next, take your drum key & tighten all the lugs....start by going around the drum, tightening each lug 180 degrees....do that twice.
If the head isn't near the pitch you want it to be at this point, go around the lugs turning each one only 90 degrees, until the pitch is close to what you're looking for....remember, keep using that pattern around the drum to keep the tension even.
Once you have the overall pitch of the drum close to what you're looking for, hit the head with the drum key about 1" from the rim at each lug. Make sure you muffle the head with your other hand right after you hit it, so you only get the main note (pitch) the head puts out...not all the overtones.
Go around the drum a couple of times, and see which lugs are lower in pitch. It's easier to bring them up to the pitch of other lugs, than it is to tune down....I'm not sure why this is, just my experience & opinion of a few people I've read from.
Once you've identified the lower-pitched (flat) lugs, start tightening them in VERY SMALL increments, one at a time. I'm talking 1/16th of a turn at a time, until it gets up to the pitch it needs to be at to match the other lug. Keep in mind, THIS WILL raise the pitch of all of your lugs slightly, as the entire head is being tightened as you do this. It should still be close to the pitch you reached after the 90 degree turns mentioned above.
Because of this, you may get one lug in tune, and go to the next one to find that putting it in tune places your last lug back out of tune.....that's expected. That's why small incremements, and patience pay off....the bigger turn you take on the lugs at this stage, the more you effect the entire drum. To combat this, I try to tune at this stage using the same pattern I used when tightening the head the rest of the time. Get one lug tuned, go to the next, etc....and back to #1 again....pretty soon, it'll just narrow itself down and everything will be good to go.
For the top head....repeat this same procedure, making sure that the bottom head is completely muffled so you only hear the top head while you're tuning it. The cool thing about the top head, is how its relationship with the bottom head will affect the drum's sound. Personally, I tune my top head about a third in pitch lower than my bottom head, so the sound of the drum will bend down in pitch to the next drum.....I tune each drum a fourth in pitch apart.
There are a TON of different things you can do with the relationship between the heads and drums....probably better to put that in another thread if it's needed!
Someone let me know if I left anything out....
Old 11-03-2005
bair_ohio bair_ohio is offline
Junior Member
bair_ohio is on a distinguished road
Hmmm..
Say there are 4 lugs(for Easy directions)
Tune at the 12 and 6 o'clock positions and then the 9 and 3.
Tap the drum head about an inch or two in from the the nut on both sides. tighten or loosen till they match.
Sounds sill but thats pretty much all it is. Take note that almost all people tune the kick and floor toms too low. its your mind playing tricks on you.
If that fails you then go buy a drum tuner. Yup they sell em.
Old 11-03-2005
Junior Member
Thanks!
Thank you both very much.
In particular, funkdrmr said some things that really clicked. I will be working on this all night I've decided until I get it. I will hit the drum in the morning, lol.
Do you mean they actually sell drum tuners? How does that work?
Old 11-03-2005
Senior Member
The Drum Dial...you can google it. I've never used it, but apparently it tells you the tension at each lug, so you can get the same tension all the way around.
Even some professional reviews of that tool have said to still learn by ear.....kind of like learning your rudiments. It's the basics that count. Once you have those down, you'll know how to properly use the tools provided to make life a bit easier on yourself if you so choose.
Here's a pic of how to go around the drum evenly.....
http://www.musiccenters.com/bin/Head_1.gif
Old 11-04-2005
drummerdude666's Avatar
drummerdude666 drummerdude666 is offline
immature
drummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond repute
I have a Drum Dial (well the tama equivilent, called a tension watch). They do work.
I can tune drums, but i have to tune up drums so often and you always have that 'off day' where it just doesnt quite sound right. Those days always happened at important gigs, teaching kids how to tune etc.
Anyway, i decided to try one out to see how well they work, and they're good. More importantly it'll show you how tuning works. By tightening one lug, your not just tightening around it...but also at diffrent places all oer the drum head.
It will give you a glimpse on how tuning works and will help you learn to tune by ear.
Ever notice that people labelled eccentric are usually geniuses?
Old 11-04-2005
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
link
This is from the drum tuning bible, and if you scroll down to where it says "tuning" it is very similar to what funkdrmr said. Maybe you just missed it???
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Electronic Drum Set wakeupbomb Newbies 9 12-17-2004 09:13
wat it takes for kick.. mic or treatment. lbcstudios Drums and Percussion 11 02-27-2004 19:47
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
Drum Tracks: GT Pro vs. HS 2002 Bill Colbert Cakewalk / Sonar Forum 2 04-09-2002 04:54
How do I remove bass drum from overheads? guitarsg1 Recording Techniques 3 03-25-2002 20:45
