amp experts - vintage amp question
what is the difference between the marshall jmp and the vox ac-30? I believe they both use EL34's and have similar controls. are they meant to be similar? I was also wondering about the JCM800, which can also run on EL34's. Is this meant to be a circuit-board version of the JMP? Are all of these amps pretty much the same?
AC30 = EL84 EL84 is much smaller of a tube.
thanks. what about the jmp/jcm800?
Though the JCM800 model 2203 and the late 70's MasterVolume heads are the same circuit inside as each other. They just have a different housing.
If I try to find a hand-wired head, will I be able to duplicate the JCM800 sound? |
Just for starters the Vox AC 30 employes a power section that uses a Class A 30 watt design. The Marshall JCM 800 is a 100 Watt Class A/B design. Both Amps are totally different in the preamp and power amp section as well as power output. Then there is the speakers, don't get me started
. All great amps. |
You are looking in the wrong places IMO. Some of the earlier of late 70's were handwired if I recall, but they had inconsistancies in sound quality....or so they say. Handwiring isn't all its cracked up to be. A well designed circuit board layout with good components will sound every bit as good, but have a lot better consistancy from amp to amp. but back to this part..... "If I try to find a hand-wired head, will I be able to duplicate the JCM800 sound?" if you want to duplicate the JCM800, why not just go buy an actual 1980's model 2203? Why bother duplicating what already exsists?.....and is much cheaper.
well, right now I am playing a Crate Vintage Club 50. Which is an excellent amp. It is a sort of knockoff of the AC30. Or at least it runs the same tubes and has a similar sound. I'm not totally happy with my tone though (is anyone ever?) I went up to NY and played a vintage AC30 and wasn't stunned really. so I am looking into the marshall alternative. I don't really dig the marshall drive channel but if I could find a quality hand-wired head that ran EL34's at about 50 watts without a master volume ...I think I would be more than satisfied.
New one: what is the difference between the JTM45's and the earlier JMP 50-watters? |
| Adding an external speaker out to vintage amp question. | Scooter B | Guitars and Basses | 8 | 05-15-2008 17:50 |
| How do you get guitar feedback when an amp is out of the question? | dogbiscuit | Recording Techniques | 32 | 05-30-2006 11:17 |
| an odd amp question | little guy | Guitars and Basses | 33 | 07-26-2005 14:26 |
| Alamo Amp Question | kronick | Guitars and Basses | 2 | 02-18-2004 12:23 |
| Power Amp wattage question... | Simmons | The Rack | 16 | 02-14-2004 00:31 |
