Old 10-09-2000
Nilbog's Avatar
Nilbog Nilbog is offline
hello
Nilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond repute
...as an RCA patchbay?
I want to be able to switch my RCA stereo outs between my amp, cdr, and minidisc recorder.
I'm sick of reaching around back and fiddling with things.
Any ideas?
Old 10-09-2000
JC Lives's Avatar
JC Lives JC Lives is offline
Dedicated Member
JC Lives is on a distinguished road
About 7 or 8 years ago, I had several tape decks and not enough inputs in my receiver to hook them all up and be able to record from one macine to the other. I found a tape switching box at Radio Shack that solved my problem. It had 3 tape in and out and each one was switchable. If I remeber correctly, it was only around $25. I don't know if they still make them. If not I sure they would have something similar. Check it out dude.
Old 10-09-2000
ffmada ffmada is offline
Senior Member
ffmada is on a distinguished road
I use a Radio Shack thing just like that. I am pretty sure they still make them, because I just got one about four months ago.
madfadder
madfadder
Old 10-09-2000
bvaleria's Avatar
bvaleria bvaleria is offline
Recording Genius
bvaleria will become famous soon enough
I thought Tascam and Furman both have RCA-connector models....
Bruce
Old 10-10-2000
Nilbog's Avatar
hello
I'm scared of putting my prescious sound through anything bearing the name "Radio Shack". I swear, you buy a toaster from those guys, and your stereo starts sounding bad.
Maybe I'll just buy a bunch of RCA-1/4" adapters.
Old 10-10-2000
John Weigel John Weigel is offline
Senior Member
John Weigel is on a distinguished road
You can make a relatively inexpensive "patch bay" for yourself with a 1-U rack panel and the connectors you want to use (RCA, phone etc). It won't be as "cool" as a store-bought model (no normalized inputs and so on) but if you have just a few devices to connect and your configuration won't be changing, it's pretty easy. I made one using phone jacks to connect my mixer-phone amp-power amp-BBE-computer breakout box setup and now I can switch one pair of cables on the front of my rack and get playback through headphones or through the apeakers or whatever. It did require both planning and redoing after I tried out the original layout. The cables that connect to the mixer, amp, etc, by the way, don't "patch" into the back but are hardwired to the front panel jacks. This is where a real patchbay is much better for a complex layout where you are going to be using many different devices in the course of a project.
A couple of tips: use a steel rack panel and mount the jacks near the outside edges to minimize flex when you pull and push on the plugs to make connections.
Also, if you don't have a rack, you can wire the connections into a desktop box that will sit better than a rack panel on a flat surface like a shelf.
John
Old 10-10-2000
Senior Member
Exclamation
whoa, I just re-read your last post: avoid using RCA-phone adapters! I learned the hard way that the tips of the adapters ("hot" connection) can pull out when you yank on the cable to disconnect, and the tips will stay inside the jack until you go in after them. I dismantled my brandnew headphone amp to retrieve them little buggers and I am now a committed to soldering on the appropriate plugs.
John
