Recording bass
Hey all
I am looking to record a bass player and am trying to understand the best way. I will give you what I think are my options. Direct xlr out on the head into a Yamaha MLA7E pre amp. From there the pre amp goes into one of my interfaces into the computer. Or option 2. Direct xlr out on the head into a mixer we use for the pa and sub it out to the interface and dont put it in the main mix. Is going into a pre amp directly to much pre amp? Isnt it going into the board via xlr's the same thing? Thanks in advance for the advice |
Anyone wanna chime in?
Can you record two tracks simultaneously - the direct track and the bass cab with a mic on it? It's always helpful for me to have the two and blend them as I need to.
I don't understand how your two options are that much different.
I propose option 3: Use a DI box. Keep it simple! |
I agree with the DI. One of the difficulties in recording bass is that most project studio rooms have a lot of mud down in the bass region, and when you record a bass amp, you inevitably pick up the mud along with the tone. If your bass player has a problem with DI, use a direct box as follows: plug the bass into the box, run an XLR cable to the mixer, and another cord to the bass amp, and let the bass player hear himself through the amp while you get the signal through the direct in.
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23 |
I've read here (but haven't tried yet) that if you're recording direct that some people will also put a mic to the bass strings and record that to a separate track. This way you can mix it in later to add some clean attack. Sounds cool, I'm definitely going to try it myself .
www.myspace.com/psychoticovertones |
The important word for recording electric bass is "DIRECT." Bass is a nightmare to properly record from microphone unless you have a really well-designed pro studio, pro engineering and pro gear -- and then it's merely very hard.. This is axiomatic. You may think your mic'ed bass cab sounds OK, but you take it in for pro mixdown and mastering and the engineer's probably going to say, "Uh...can we re-do those bass tracks?" ![]() |
What's the bass amp that you're using?
If the direct out on the head is a preamp output, just run that directly into your interface. If it just parallels the input signal, you'll need to run it to a preamp first. Chances are that its a preamp output though, so you shouldn't need an external preamp. |
| Which bass for recording that modern deep tone all rockers use today? (Nickelback...) | StarSyn | Guitars and Basses | 12 | 09-30-2005 09:05 |
| Anyone have advice on recording jazz fusion bass? | ProgMetalShred | Recording Techniques | 11 | 09-07-2004 00:28 |
| Anyone have advice on recording jazz fusion bass? | ProgMetalShred | Guitars and Basses | 1 | 09-04-2004 21:01 |
| aardvark direct pro user.... Advice on recording DI Bass needed | Rassoodocks | Recording Techniques | 13 | 06-24-2003 07:09 |
| Help choosing a bass for recording | mcmd | Guitars and Basses | 9 | 08-13-2001 14:07 |
